The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Power Supply Soft Start Board (V3)
Old 31st December 2013, 02:27 PM   #11
clucka is offline clucka  United States
Send a message via AIM to clucka
Will there be a build guide for V3? I have the boards and will be ordering parts. Would like to be aware of best practices around hooking up and turning on.
Thanks,
Curt
Old 31st December 2013, 03:04 PM   #12
6L6 is offline 6L6  United States
6L6's Avatar
Yes, there will be a guide. I have the PCB, but haven't yet ordered parts. (I'm currently out of town, and in your neck of the woods for a few more days...)
Old 3rd January 2014, 02:01 AM   #13
BigE is offline BigE  Canada
BigE's Avatar
Can this be converted to a slow cap charge circuit? or is that simpler? ie, an RC network with time constant selected to ensure that the relay's pull in voltage is created at a delayed time?
Old 3rd January 2014, 03:37 AM   #14
6L6's Avatar
That is the operation of the circuit.
Old 4th January 2014, 11:44 AM   #15
BigE's Avatar
Thanks! It looks to me like one would change R19 and C10 for adjusting relay operation time, as well as R15-R18 to adjust power requirements.
Old 4th January 2014, 10:09 PM   #16
BigE's Avatar
Oops, not R19, R14! Must try LTspice....
Old 7th January 2014, 03:51 PM   #17
BigE's Avatar
What is the maximum size toroid that can be started with this soft-start? I am a novice, looking at the relay spec sheet, trying to understand what are the limiting values....
http://www.components.omron.com/comp...5LA_E_0911.pdf
Any help is very appreciated, as I will need a soft-start for my toroid and also need speaker protection due to DC couple pre and amp.
Thanks!
Old 7th January 2014, 04:07 PM   #18
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
I have been running a 1kva toroid with a combined filter capacitance of about 160kuf for about 3 years now. All with the supplied values in the BOM.
Have you read the build guide? It should help you in fine tuning the soft start if needed.
Old 7th January 2014, 04:21 PM   #19
BigE's Avatar
Yes, I have read the build guide, and it does say you can have some big toroids.
My toroid is a universal 2.4 kVA, with 5 60-0-60 outputs that can be wired to provide between 36 and 30 volts volts -- for a max of about 1.5 to 1.2 kVA.
This is going into a high bias F5T with 4 pairs of outputs per channel at about 45 volt rails. The bias current is limited by the heatsinking, which should manage around 3 amps per channel.
Yes, this toroid is stupidly oversized, but it is not great sounding as a balanced power source -- which was it's original purpose, and I want to reuse it... or sell it....
THANK YOU!!!
Old 7th January 2014, 04:55 PM   #20
JojoD818's Avatar
Well I think for amp builders there is no such thing as oversized.
Iirc, the largest load I had used the parts values in the BOM is for a two-toroid setup that has a combined rating of about 2kva only. I never actually worried too much about the relay since once the caps have their initial charge, shorting out the limiting resistors wasn't much of a problem.
Loading lots of capacitance and the extra load of the amp may need you to adjust the values of the limiting resistors so they don't get too hot during power ups.
Fwiw, my CNC's motor psu also uses the same soft starat. With 3 hungry Kelling stepper motors that each draws out about 4A during hold modes also uses the same relay in the BOM.
Power Supply Soft Start Board (V3)Hide this!Advertise here!
diyAudio Power Supply Circuit Board v3 illustrated build guide 6L6 Power Supplies 674 21st April 2018 10:31 PM
V3 Universal Power Supply Circuit Board Jason The diyAudio Store 370 15th March 2018 07:38 AM
Power Supply Soft Start Board (V2) Ana The diyAudio Store 194 18th September 2014 08:42 AM
soft start power supply for dynaco st-70 yero Tubes / Valves 9 8th July 2011 08:43 PM
Commercial Soft Start board wytco0 Parts 0 5th August 2005 04:26 PM
