The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V3)
Old 5th November 2017, 07:06 AM   #311
R.I.P.
the speaker isolation relay should isolate (open contacts) when power is OFF.
check you have used the normally open contacts.
When the relay receives the signal to trigger/switch over, the relay contacts close and the speaker becomes connected to the amplifier.
A normally closed relay is no good for speaker protection.
regards Andrew T.
Old 5th November 2017, 03:21 PM   #312
antanasgrigas is offline antanasgrigas  Lithuania
Hi Andrew T.
When power is off, relay contacts is open. I check with multimeter. But, when amplifier power on, relay contacts do not close, and red led does not stop blinking. Loudspeakers are disconnected from the amplifier.
Only after the speaker protection bord "IN" is disconnected. The relay closes and the LED stops flashing.
I checked again. The output of the amplifier is DC zero
Old 6th November 2017, 06:20 AM   #313
Thank you very much for help.
I found ... It was necessary to connect one board power cord to the transformer's secondary and the other to the ground of the power supply unit.
Old 6th November 2017, 02:58 PM   #314
kpsthakur is offline kpsthakur  India
Default Transistor replacements
Originally Posted by JojoD818 View Post
I haven't tried BC549 in there but a quick peek and I don't see why it wouldn't work. 2N2222 is also ok in lieu of the 945. 2SC828 is also a pin for pin replacement.
Just please watch out for the pin configuration when you substitute transistors.
Cheers
I think 2N2222 is a pin to pin replacement for KSC945YTA with few changes in characteristics...I am using a 12V version for DC protector circuit, hopefully this should be sufficient
For MPSA06, can I replace it with 2N5551, stats read much more that MPSA
C-E Voltage 160V
C-B Voltage 160V
E-B Voltage 6V
C Curr Cont. 600mA
I have plenty at hand...hopefully they are good to be used for Q4
Old 7th February 2018, 01:46 PM   #315
coolnose is offline coolnose  Europe
coolnose's Avatar
Hi All,
I just test my 2 builds. One is V2 , the other V3. I took care of the changed pinout of the transistors on the different version. Both builds act the same.
On power on led 2 turns on, led 1 flickers, the relay engages after a while and turns led 1 definitely on, the other stays on as well.
On turn-of led 2 dims slowly and led 1 flickers off....
The only change I made is 330uF in C6 instead of 220uF ...
Max
Old 7th February 2018, 03:26 PM   #316
coolnose's Avatar
Actually I think both boards are working fine, I'd just like to lower the flip flop frequency of LED1 as I expect the flickering to indicate a proper function, just to quickly ....
Just tested 4.7uF instead of 2.2uF for C1/C2 ... no change.... I suppose altering (increasing) R2/R3/R4 will slow down the blinking led ... any suggested value instead of 33K ?
EDIT: 2 x 10uF does the job for me, no resistor changes.
I understand that the speaker protection board cannot be used in a double mono configuration .... what PSU ground would the board be referenced to ...? So one board to order...
Max
Originally Posted by coolnose View Post
Hi All,
Max
Old 12th March 2018, 04:38 PM   #317
captJackSparrow is offline captJackSparrow  India
Default DC protection board
What is the maximum current draw by DC Protection circuit, I am using one from store and Omron G5LE-14 5VDC relays.
My transformer is 15VA, would it be safe to run 2 fans(each 12V .39 amp max draw) along with DC Protection circuit off the same transformer?
Thankyou
Old 5th June 2018, 10:46 PM   #318
YouAgain is offline YouAgain  United States
Default Engagement voltage and isolation from chassis ground
This might help you if you want to use the protection board and still maintain some ground isolation between the left and right channels on your power supply.
I built the speaker protection board for my Pass A6 project which is being built as independent mono blocks in a single case with one protection board. I wanted to preserve ground isolation between the left and right channels. The idea was to use a chassis ground as the single bonding point between channels but have some isolation between signal ground and chassis ground and isolation between left and right power supply grounds. The Pass schematics show a CL-60 thermistor for isolation between signal ground and chassis. The CL-60 has 10 Ohms of resistance when cold. I'm going to use a 10 Ohm resistor in parallel with two pairs of two series connected diodes paralleled in opposite directions in my amp. I'll have one of these isolation networks for each channel. Since the speaker sense circuit of the protection board shares a common ground for both channels, I did a test to prove that having the ground isolation network in series with the sense ground will not affect the performance of the protection board's sense circuit. To test I connected the speaker terminals on the protection board to a bench DC power supply and slowly increased the voltage. I found that it engaged the protection at 2.1 Volts DC. Then I placed the ground isolation network in between the sense ground and the power supply and I repeated the test and found the trip point was still 2.1 Volts DC.
Old 6th June 2018, 02:47 PM   #319
BigE is offline BigE  Canada
BigE's Avatar
To be clear, you hooked up one ground isolator for each channel at U1.1?
Old 6th June 2018, 10:49 PM   #320
Yes but let me clarify. The U1 connector is the power supply input for the speaker protection board. My speaker protection board's power supply is it's own separate supply that floats. My U1.1 connects directly to chassis ground for the ground reference relative to the amp's speaker's ground. Each channel's power supply ground (shown as PG-1 on the amplifier boards) connects to their own ground isolator which connects to a single star point on the chassis ground. So each amp has only one connection to chassis ground via a ground isolator and the speaker protection board only to chassis ground.
Speaker Turn On Delay and DC Protector Board Set (V3)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V2) Ana The diyAudio Store 185 16th February 2018 02:08 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 06:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 07:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 09:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 05:57 PM
