The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
diyAudio F5 Build Guide
Old 2nd March 2017, 01:28 PM   #21
6L6 is offline 6L6  United States
6L6's Avatar
Just saw this.
Please post well-lit, in-focus photos. We'll see what we can see.
Originally Posted by GordR View Post
Looking for some help. I just finished assembling F5 amp using v3 boards/schematic and when I powered up to check/set bias things went up in smoke! In particular R7 and R8 lit up and Q1 and Q2 "popped". Looking at board it appears a few other resistors got hot too...R14, and R4 showing discoloration.
Old 2nd March 2017, 05:17 PM   #22
GordR is offline GordR  Canada
Originally Posted by mattattnet View Post
I would try asking at the F5 Build guide thread for help:
An illustrated guide to building an F5
Thanks! I have posted there now too and seem to have traced the fault to sketchy ebay Jfets.
cheers
Old 11th March 2017, 06:19 PM   #23
kpsthakur is offline kpsthakur  India
Well i am moving ahead slow and steady for the F5, just got over the power supply stuff. I am using a 2 X 18V, 600VA toroid. Funny thing is when I power it on, it humm's a bit and supply looks good...but when I switch it off and restart...it trips me power supply. Fortunately I have MCB's so I need to keep switching them on...am I missing something here??
Sent from my iPhone using Tapatalk Pro
Old 11th March 2017, 06:28 PM   #24
6L6's Avatar
What are the resistors on the output?? You don't want them for a Class-A amp.
The caps appear to be a short circuit when they are discharged, and with a 600VA transformer there is the possibility of drawing A LOT of current from the wall when you switch on. I suspect the circuit breaker is getting hot from the first power-up and the subsequent cycles are heating past it's trip point.
Use a CL-60 in series with the live to control the inrush.
Old 11th March 2017, 07:12 PM   #25
Humm...I have a 1ohm 3W snubber resistor & 0.1 uF 63V capacitor
Old 19th March 2017, 08:37 PM   #26
Not a happy report, first attempt failed...smelled the magic smoke...its 2 in the morning...no energy left to diagnose ....done for the day
Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.Click the image to open in full size.
Old 19th March 2017, 08:39 PM   #27
Not sure, but the 600VA teddy seems too much for the job diyAudio F5 Build Guide
Old 25th August 2017, 05:39 PM   #28
ericacaylar is offline ericacaylar  United States
Default F5 V3.0 build
Hi!
I just bought these diyAudio F5 boards to build the amp. But I couldn't find a specific build thread or BOM for these V3.0 boards. I even made the mistake of buying 2 completely forgetting 1 is for a pair. Now I am stuck in the middle. Please help! I am a complete newbie at this.
ericacaylar
Old 2nd May 2018, 05:48 PM   #29
adason is offline adason  United States
adason's Avatar
all the info is on the bottom page of diy store where you bought the boards
class A not the best way to start building amps
I would suggest few chip amps first but its up to you
Old 2nd May 2018, 05:50 PM   #30
adason's Avatar
power rating of the transformer is irrelevant, as long as its above the minimum recommended
diyAudio F5 Build GuideHide this!Advertise here!
An illustrated guide to building an F5 6L6 Pass Labs 999 30th May 2018 10:33 PM
MyRefC build guide AndrewT Chip Amps 1119 29th July 2016 10:30 PM
Guide to build Hypex Modules souldriver Class D 85 16th July 2011 07:29 PM
DIYaudio F5 V2 mounting holes sts9fan Pass Labs 1 28th February 2011 11:04 PM
