The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Cviller's F5c
Cviller's F5c
Old 11th January 2013, 02:17 AM   #1
thor61 is offline thor61
Default Cviller's F5c
Could someone please give me a basic ideal psu description if building the F5c ? What I need to know is how much capacitance is needed, also the transformers Va. and voltage ratings. I have enough cap's for 180,000uf @ 50v and could probably purchase a 600 Va transformer... Any help would be greatly appreciated ! Thank's
Old 15th January 2013, 07:27 PM   #2
cviller is offline cviller  Canada
cviller's Avatar
Hi Thor,
How hard are you planning on biasing it and what voltage? A normal F5 is ok with 300-400 VA toroid and 8x22mF caps.
Old 15th January 2013, 07:59 PM   #3
I'm not really sure as my heatsinks are rated at 0.28 c/w per channel or side. Any advise would be greatly appreciated. I would like to use the cascode option though.
Old 18th January 2013, 07:23 AM   #4
cviller's Avatar
I cannot remember the exact requirements, but with that sink, you will not be able to push it much beyond stock F5 bias and voltage (unless you install a fan).
Old 1st February 2013, 04:54 PM   #5
Has anyone built a amp based on using these boards ? And if so could one post some construction details ? Click the image to open in full size.
Old 1st February 2013, 05:28 PM   #6
cviller's Avatar
What kind of construction details are you looking for? I guess you can find some of the info you need here:
http://www.diyaudio.com/forums/blogs...version-2.html
And you can also get inspiration here: (basically the same layout)
F-5 clone boards (2 PCBs, makes 2 channels; Rev 2.0) - First Watt Clones - Power Amplifiers - PCBs
Old 1st February 2013, 06:13 PM   #7
Cviller, Thanks for the quick reply ! I have all of your pcb's F4, F5, and F5c. My I'm not sure as to which one to build as I'm looking for 60 wpch or better @ 4 ohms. Can't find a lot on the F4 or the F5c which is the one I hope to build. My heat-sinks are 0.26 c/w and I plan to use copper heat spreaders... My transformer is a Antek AS-4218 2x18v @ 400Va And the psu caps are 40v 15,000uf x 12. I plan to use 6 each per channel via Chipamps.com's psu pcb's giving me a total of 180,000 uf ! Any help instrumenting a build based on this info would greatly help..... Thank-you
Old 2nd February 2013, 06:06 AM   #8
cviller's Avatar
If I were you, I would probably build a double output F5 aka F5 Turbo. If you have not built amps before, you should probably take your time to read through the F5 Turbo thread and read the article by Nelson Pass.
Old 3rd February 2013, 12:09 AM   #9
Here is a link for the Heat-sinks I have, what would be a good bias point to shoot for if using two per side ? Don't forget I plan to use 0.25 x 2.0 x 4.5 copper heat spreaders to mount the mosfets on. See Link > http://www.newark.com/h-s-marston/938sp-02000-a-200/heat-sink-extrusion/dp/08WX9554
Old 3rd February 2013, 05:28 AM   #10
cviller's Avatar
With those, I think you should aim for stock F5 bias.
Cviller's F5cHide this!Advertise here!
F5X from diyAudio Boards P-F5c-2V20e JBL4435 Pass Labs 55 10th January 2017 06:18 PM
F5c question mk57 Pass Labs 1 28th August 2012 09:50 PM
SMPS for DIY Audio F5c Einric Pass Labs 10 21st August 2012 12:45 PM
F5c Transformer Einric Solid State 0 2nd May 2012 05:24 AM
WTB: cviller's 1.0 F5 pcb merlin2069er Swap Meet 0 10th July 2011 04:33 PM
Copyright ©1999-2017 diyAudio
