The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Cviller's F5c
Cviller's F5c
Old 5th February 2013, 02:11 AM   #11
thor61 is offline thor61
Do I use R111 & R112 as bias test points ? See pic > Click the image to open in full size.
Old 19th February 2013, 04:49 PM   #12
coils is offline coils  United States
Those are the correct r's for monitoring the bias current, actually, any one of the 11, 111, 12, 112 will work, with well matched parts, the volt drop across them will be the same, so you can just monitor one. If you have multiple dmms, monitor an n and a p simultaneouly, and with another monitor the dc on the output of the channel.
Coiler
Old 19th February 2013, 04:59 PM   #13
Cviller, Thanks for the quick reply ! I have all of your pcb's F4, F5, and F5c. My I'm not sure as to which one to build as I'm looking for 60 wpch or better @ 4 ohms. Can't find a lot on the F4 or the F5c which is the one I hope to build. My heat-sinks are 0.26 c/w and I plan to use copper heat spreaders... My transformer is a Antek AS-4218 2x18v @ 400Va And the psu caps are 40v 15,000uf x 12. I plan to use 6 each per channel via Chipamps.com's psu pcb's giving me a total of 180,000 uf ! Any help instrumenting a build based on this info would greatly help..... Thank-you
If you want 60wpc, I would build the F5c. You wont need to cascode with your 18 v xfmr though (uless you have enough secs to series them). And at 400va, its not really for a hot rod F5, unless you have two of them, one for each channel. Your xfmr is perfect for a stock F5 though.
How many sinks per channel are you going to use? They look like you will need two per channel. I dont think one per channel will work at a respectable bias level.
When you build it, and are ready to bias it, just let your sinks decide. Slowly start to bias it, letting it warm up as you go. If your sinks get too hot, you can back off some. The biasing procedure is the funnest part of the build, and it offers a lot of flexibility to adapt to your sink capabilities.
Coiler
Old 20th March 2013, 07:05 PM   #14
Rixsta is offline Rixsta  United Kingdom
Cviller's F5c
Ok Ive been reading about this PCB and have a little confusion as the wording used about it is diferent to nelsons PDF.
the F5c boards, will make the double output F5 Turbo, Ill end up with 50w F5 ? will it also make Version two ? can i make V2 work with this board ?
www.rikibuckingham.com...
Old 23rd March 2013, 04:16 AM   #15
Yes, the F5c boards can make F5Tv2, and can easily achieve 50 watts class a into 8 ohms, if you have the rail voltage and enough sink to bias it. You will have to hard wire P3 and the parallel source diodes.
here is a pic of mine. It is not cascoded, and I did not install P3. Its not difficult to build it this way, or you can wait for turbo boards.
Coiler
Old 1st June 2014, 09:49 PM   #16
cdfac is offline cdfac  United States
Old thread I know, but I am looking into building a Turbo V1 with this version of the cviller F5 pcb, which I just picked up in a bundled purchase. The main question I have is about the difference in the thermistor circuit. In the Turbo circuit, one leg of the thermistor/2.2kR combo goes through the source resistor before hitting the voltage rail, while in the original F5 circuit this leg connected directly to the rail. I suppose that there really isn't a huge difference at first glance considering the resistances involved (2.2kR and 0.47R). It will not be difficult to wire this board to follow the new design, but I'm just curious whether it's necessary or at least a good idea to do so. Any guidance on that would be appreciated, thanks!
Also, I knew that the V2 could be built on this board (and similarly the F5c board), but the previous post on this old thread makes it look even easier than I expected! Nicely done
Old 2nd June 2014, 07:18 PM   #17
toxic ingestion is offline toxic ingestion  United States
I asked cviller about this previously and it is fine and has been suggested in the past by NP. I have used this board and it works fine. I have some upgraded boards cviller designed with P3 and resistors to the bases of the cascoders if you are interested.
Cviller's F5cHide this!Advertise here!
F5X from diyAudio Boards P-F5c-2V20e JBL4435 Pass Labs 55 10th January 2017 07:18 PM
F5c question mk57 Pass Labs 1 28th August 2012 10:50 PM
SMPS for DIY Audio F5c Einric Pass Labs 10 21st August 2012 01:45 PM
F5c Transformer Einric Solid State 0 2nd May 2012 06:24 AM
WTB: cviller's 1.0 F5 pcb merlin2069er Swap Meet 0 10th July 2011 05:33 PM
