The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V2)
Old 7th December 2012, 09:37 AM   #21
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Please check T1 and T2 for proper lead orientation, R1 thru R4 and C1 and C2. It should blink, especially if it's purple! ;D
Cheers
Old 7th December 2012, 09:41 AM   #22
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
It should blink Christmas style!!!!Ok, I'll check and get back to you.
Thanks!
Old 7th December 2012, 10:40 AM   #23
Nikitas's Avatar
The pinout is ECB and it's placed ok. Could you please take a look at the datasheet, maybe you will see something that I've missed. Maybe these TRs are not suitable for this circuit.
Old 7th December 2012, 01:46 PM   #24
JojoD818's Avatar
as a general purpose transistor it looks good to me... btw, a reversed D5 can stop the LED from blinking too....
Old 9th December 2012, 07:29 PM   #25
McQuaide is offline McQuaide  United States
Hi all, I'm putting my Mouser order together for the Speaker Protector and Softstart boards and I could use some recommendations. Can anyone point me to Mouser items for the Euroblock, Faston terminals, standoffs, and LEDs?
Also, how about a set of gold plated speaker binding posts?
Thanks!
Old 9th December 2012, 11:21 PM   #26
JojoD818's Avatar
Hi, I'm also putting together the part numbers for Digi-Key, unfortunately it's not finished yet.
Old 10th December 2012, 10:41 PM   #27
Would this work for the terminal block?
1729128 Phoenix Contact | Mouser
Also, here are some faston terminals:
http://www.mouser.com/Connectors/Ter...rminal&FS=True
Old 10th December 2012, 11:42 PM   #28
JojoD818's Avatar
That terminal block looks ok. As for the faston terminal this one should work ok 63949-1 TE Connectivity / AMP | Mouser
Old 10th December 2012, 11:45 PM   #29
Thanks! Any recommendations for LEDs?
Old 11th December 2012, 12:01 AM   #30
JojoD818's Avatar
I use whatever I have in the DA parts Bin. I tried red, yellow, blue 5mm and 3mm rounds and some rectangular too no problem. Just workout their lead orientation, otherwise they won't light up.
It's more up to your liking really.
Speaker Turn On Delay and DC Protector Board Set (V2)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V3) Jason The diyAudio Store 319 6th June 2018 10:49 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 06:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 07:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 09:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 05:57 PM
