The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V2)
Old 13th August 2017, 02:07 PM   #181
McQuaide is offline McQuaide  United States
First let me say that the unit works as advertised and passes the DC test in the build guide.
The voltage was measured at the speaker binding posts with the amp running. There was no offset voltage at the amp outputs but voltage at the protector board outputs.
I bypassed the protector board after finding this.
Old 13th August 2017, 02:10 PM   #182
The Fluke meter is on the binding post, the other two are on the F5 board.
Old 13th August 2017, 02:29 PM   #183
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Let me get this straight, you moved your test probes from amp output to protector board output without doing anything else?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 13th August 2017, 02:42 PM   #184
Yes.
Old 13th August 2017, 02:49 PM   #185
I presume you can see how if your wiring is correct and the relays are working properly, that makes no sense. Try shorting across the relay contacts, if everything else is correct I can only suggest the relay contacts
Old 16th February 2018, 02:08 PM   #186
Zatopek is offline Zatopek  Germany
Question Relay voltage
Hi gents,
as I do see the need for such circuit as well, may I please join the thread. Can you please help me understanding the schematic by answering 2 questions:
I happen to have a handful of relays OMRON G2RL-2 12V and a transformer fine to get me 15VDC. The schematic is showing the 2 relays in series:
1) Why can I not use the 2 relays in parallel so they are OK for 12-15V operation??? I am not using the DIYAUDIO PCB but rather do a wild wiring so the Change of layout does not matter
2) Why do you use 2 relays at all? Why not just use the 2 contacts you have anyway in 1 relay?
Worried about crosstalk??
Speaker Turn On Delay and DC Protector Board Set (V2)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V3) Jason The diyAudio Store 319 6th June 2018 10:49 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 06:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 07:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 09:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 05:57 PM
