The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V2)
Old 21st January 2017, 04:15 PM   #171
McQuaide is offline McQuaide  United States
Originally Posted by McQuaide View Post
I used this one for T6
MPSA06 Central Semiconductor | Mouser
And these for T1-T5
2N5232A Central Semiconductor | Mouser
I'll check the resistors one more time but I think they are right. I just went over the Mouser BOM I used, and all the right values were ordered.
Sorry for the giant photo...
Quoting myself here, I dug the speaker protector out of a drawer (I had given up) and found a simple bad solder joint. The unit now works as advertised and passes the test when connecting the amp in to D6.
Is there a good way to test this board with a battery? At what DC voltage should the relay open?
Old 22nd January 2017, 08:25 AM   #172
Most will trigger @ 1.5Vdc from a battery.
Some will trigger slowly at this voltage, others trigger quickly.
The real test is to apply a half power to full power signal from the power amplifier and slowly decrease the frequency from 100Hz to 5Hz and see if it triggers cleanly when the frequency is below 20Hz. You don't want false triggering of audio frequencies that could be valid signals.
regards Andrew T.
Old 22nd January 2017, 01:38 PM   #173
Dumb question, but how is the battery connected? Negative to the amp circuit ground?
Old 22nd January 2017, 04:17 PM   #174
The 1.5V battery should trigger the DC detection in either direction.
regards Andrew T.
Old 23rd February 2017, 02:06 AM   #175
mattmcl is offline mattmcl  United States
Originally Posted by ncg2013 View Post
Hi All, I hope someone can give me some guidance here I have just finished filling the speaker protector board V2 and starting to test. When powered up led 2 is lit and led 1 is lit steady but does not flash as it is supposed to. The relays engage. Both DMM do read zero resistance. When I do the DC protection test I do not hear the relays disengage, no protection! I have checked the orientation of the transistors these are ok. I have used all the suggested components on the BOM. Transistors for T1 to T5 are KSC945CGBU and if i have read the spec sheet correctly have a pin orientation of ECB, and T6 is an 512-MPSA06 and pin orientation is EBC, so all transistors match the board layout. What else can i check to see what is wrong?
I'm having exactly the same issues with my V2 board. I don't have a record of what parts I used but I too followed the V2 build guide. What did you do to fix?
Old 23rd February 2017, 11:29 PM   #176
And these for T1-T5
Did you have to bend the legs of these, or were they the correct configuration?
Old 12th August 2017, 03:29 PM   #177
So I was re-biasing my amp and checking DC offset, and found 170mv DC on one channel and 60mv on the other. Turns out it's the speaker protector board putting this out, the amp is putting out zero. Is this normal? I took it out of the circuit for now.
Old 12th August 2017, 06:51 PM   #178
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Are you using this circuit? http://www.diyaudio.com/forums/image...-schematic.pdf
Subwoofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 13th August 2017, 12:44 PM   #179
Originally Posted by scottjoplin View Post
Yes that's the one.
Old 13th August 2017, 01:25 PM   #180
What you describe is not normal and I can't explain it. What exactly did you do when you took it out of circuit and where did you measure the offset?
Speaker Turn On Delay and DC Protector Board Set (V2)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V3) Jason The diyAudio Store 308 19th June 2017 03:29 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 06:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 07:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 09:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 05:57 PM
Copyright ©1999-2017 diyAudio
