The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Speaker Turn On Delay and DC Protector Board Set (V2)
Old 13th December 2013, 11:13 AM   #161
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
I haven't made any updates on the BOM yet but I think some changes in the connectors are needed. The other parts are basically the same I think.
Old 13th December 2013, 11:19 AM   #162
coolnose is offline coolnose  Europe
coolnose's Avatar
Thanks JojoD818, I'm going hardwired... so looks fine to me! Tnx
Old 13th December 2013, 11:52 AM   #163
JojoD818's Avatar
My pleasure.
I'm gonna look into it and update the BOMs if necessary.
Old 14th December 2013, 04:39 AM   #164
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
I've started a new thread for the V3 Speaker Protector and also for the V3 Soft Start boards. Both include the updated BOM. Please ask questions specific to those boards in those threads. Cheers!
Old 10th March 2014, 05:45 PM   #165
merlinx76 is offline merlinx76  Canada
The build guide links to the wrong file. Could you please link the proper build guide for the DC protect board?
Old 16th March 2014, 05:20 PM   #166
acumos is offline acumos  Italy
Default power supply confusion
hi guys, I know my question is a stupid question but I'm stuck. I've built my F5, it's working, sounds good, and I don't have any power on thump. So I'd like to add the dc protection board. Can I connect the X1,2 (power in of the dc protect board) to the f5 power supply (24v)? Can I share the same power supply?
Old 19th March 2015, 04:22 AM   #167
redrabbit is offline redrabbit  Isle of Man
redrabbit's Avatar
The link for the "build guide" at Post #1 is indeed the wrong one. (....it links to the "Soft Start", not the "Speaker Protector".)
I've never seen the build guide for "Speaker Protector".
I'm wondering what the Green LED is supposed to indicate.
I assume it's just a "power ON" indicator.
If so, my boards (V3) are working properly.....I get perhaps 4 second delay to close/enable the relays.
Old 19th March 2015, 07:35 AM   #168
toastedcrumpets is offline toastedcrumpets
LED2 is just a power indicator. LED1 IIRC is meant to flash while the RC-circuit/timer on the board is running (output is disabled), then becomes constant once the relay's close (and your output is enabled).
Old 13th May 2015, 02:49 PM   #169
355F1 is offline 355F1  United States
Hello,
Excuse me, where is the original article about the speaker turn-on delay construction, connections and set-up?
Many thanks,
Best regards,
Orazio
Old 4th July 2015, 11:40 AM   #170
ncg2013 is offline ncg2013  United Kingdom
Hi All, I hope someone can give me some guidance here I have just finished filling the speaker protector board V2 and starting to test. When powered up led 2 is lit and led 1 is lit steady but does not flash as it is supposed to. The relays engage. Both DMM do read zero resistance. When I do the DC protection test I do not hear the relays disengage, no protection! I have checked the orientation of the transistors these are ok. I have used all the suggested components on the BOM. Transistors for T1 to T5 are KSC945CGBU and if i have read the spec sheet correctly have a pin orientation of ECB, and T6 is an 512-MPSA06 and pin orientation is EBC, so all transistors match the board layout. What else can i check to see what is wrong?
Speaker Turn On Delay and DC Protector Board Set (V2)Hide this!Advertise here!
Speaker Turn On Delay and DC Protector Board Set (V3) Jason The diyAudio Store 319 6th June 2018 10:49 PM
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 35 2nd June 2014 06:01 PM
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 07:55 AM
DC protector ?? ping_31140 Pass Labs 9 18th January 2009 09:34 AM
DC-protector for Leach Super amp supernet Solid State 8 28th May 2002 05:57 PM
