The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Power Supply Soft Start Board (V2)
Old 1st December 2012, 12:37 AM   #21
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Just wanted to chime in with my implementation of the soft start board. My new amp has 240kuf in the solid state power supply plus another 1.2k for the tube supply. I initially chose .33uf for c9. The relay would not latch. I added another .33uf for .66uf total and the board is working as it should. The boards I have gotten from DIYaudio are great, and the excellent build guides are appreciated.
Evan
http://www.evancotler.com
Old 1st December 2012, 04:59 AM   #22
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Thanks for the feedback Evan.
Cheers!
Old 5th December 2012, 12:16 PM   #23
gabanyayaya is offline gabanyayaya  Malaysia
I'm building this soft start for my latest amp. Could somebody suggest to me a Farnell's part number for suitable relay for this circuit ?
Thank You
Old 5th December 2012, 12:27 PM   #24
JojoD818's Avatar
Perhaps this could help...
G5LA-1E 24DC - OMRON ELECTRONIC COMPONENTS - RELAY, PCB, SPDT, 24VDC | element14 Philippines
Old 6th December 2012, 11:14 AM   #25
Originally Posted by JojoD818 View Post
Thanks jojo
Any recommendation for R, C9 and fuse value for a 300VA 230VAC traffo to works at ideal condition for the soft start ?
Old 6th December 2012, 11:20 AM   #26
Be very careful changing C9.
This is a direct online mains powered project.
It is usually forbidden to discuss this on this Forum. But for some reason the usual LIFE SAFETY rule has been ignored.
As for mains fusing a close rated fuse for 300VA and 230Vac is 300/230 = 1.3A
Use a T1.25A
If this works reliably, then try reducing it to T1A and see if that works reliably.
It's OK , I have reported my own post for those that think commenting on other's decisions is inappropriate.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th December 2012, 11:40 AM   #27
Use a T1.25A
Hmmmm
I'm using a Novutem 0300P1-2-025 Toroidal 300VA 2x25V o/p Nuvotem 0300P1-2-025 to be exact and recommended fuse is 6.3AT. So why there's so much different ???
IMHO his discussion & suggestion might save my life
Old 6th December 2012, 11:50 AM   #28
An inductive load needs a very different start up fuse from a resistive load.
The "normal" fuse for an inductive load is:
fuse rating = VA / Vac * 3
300VA / 230Vac * 3 = 3.9A
Use a T4A. Most transformer will start with a T4A, some will need a higher fuse rating.
Some will start reliably with a lower fuse rating.
But this is not close rating of the fusing.
That T4A will pass 8A for many seconds and in extreme cases can exceed half an hour before rupturing.
How much heat will the faulty equipment generate if 7A or 7.5A or 7.9A is passing for 30minutes? What happens if the faulty equipment is unattended?
That's where close rated fusing offers a big safety advantage. But transformers need a soft start to allow close rated fusing to be adopted.
Yet another unhelpful post?
regards Andrew T.
Old 7th December 2012, 06:37 AM   #29
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
I think there should be some "design" notes added for the current limiting resistor values.
The 4 resistors R15 to 18 are specified @ 180r.
Is this for 110/120Vac and/or 220/240Vac?
Is this for 200VA to 1000VA transformers and/or any size transformer?
I know from experience that 45r (180/4) works on 220/240Vac for medium sized transformers in the range 200VA to 500VA.
But smaller transformers would need higher value resistors and larger transformers would need lower value resistors.
I expect that 110/120Vac transformers will generally require lower value resistors to effect similar current limiting.
A simple table showing VA & Vac combinations with appropriate resistor values would be very useful to less experienced builders.
the reason for using a startup limiting resistor is to prevent your switch from being arc welded at turn-on, in my super leach amp build with a 2kva power traffo, i used a dale 10 ohm/50 watt aluminum clad power resistor, time delay of about 3 seconds....i used a power switch rated for 15amperes...and 20 years later, the amp and its switch is still good...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th December 2012, 09:14 AM   #30
Originally Posted by Tony View Post
..............super leach amp build with a 2kva power traffo, i used a dale 10 ohm/50 watt ...........time delay of about 3 seconds...............and 20 years later, the amp and its switch is still good...
. . . . . . . . . .Vac
VA . . . 115Vac . . 230Vac
100 . . . . 270r . . . 390r
200 . . . . 180r . . . 270r
400 . . . . 120r . . . 180r
800 . . . . .82r . . . 150r
1600 . . . . 68r . . . 120r
Tony and others who feel the need to read my unhelpful posts:
The 10r Tony has used for 20years is equivalent to four (4) 40r resistors in parallel (R15 to R18 inclusive). Looking at the table that I put up for discussion I see the progression from 270r down to 68r for the range of transformers from 100VA to 1.8kVA (on 110/120Vac).
Tony's 2kVA (is this on 220/240Vac?) is just beyond that range and 40r would seem to fit almost exactly into the extrapolated range of values.
Thanks Tony for that evidence.
Has anyone else got evidence (pro/con) to put up for discussion?
regards Andrew T.
Power Supply Soft Start Board (V2)Hide this!Advertise here!
Soft Start PC Board organics1 The diyAudio Store 2 29th March 2013 04:18 AM
soft start power supply for dynaco st-70 yero Tubes / Valves 9 8th July 2011 08:43 PM
Adcom 565 DED!!! Soft Start Board? dracoskeeper Solid State 2 6th June 2010 04:29 PM
Blown 20watt 4.7uf on soft start board ben62670 Solid State 4 26th June 2007 05:29 AM
Commercial Soft Start board wytco0 Parts 0 5th August 2005 04:26 PM
Copyright ©1999-2017 diyAudio
