| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
I have a bunch of parts I ended up not using in projects. I always over order.
1x corcom switched/fused iec power entry module. $4 4x 14uf/180vac Aerovox oil caps (motor run type) says "no pcbs" $6/ea 4x 15,000uf/63v McIntosh 3 pole 'lytic caps $8/ea (never used) 10x 15,000uf/80v Cornell-Dubilier 'lytic caps $7/ea (never used) 2x 4 channel motorized Alps 50K audio taper pots $25/ea 4x 25A AC relays, bought for a power conditioner project that never panned out. I have no idea how much I paid or what they are worth, will try to look it up. 4x 15,000uf/80v Samwha Caps 'lytic $6/ea (used but not soldered) 12x 50K linear pots from All electronics...these are said to be stackable, which is why I bought them, but never did anything with them. I think they were $.50/ea, so $5 for all. I'll try to up some pictures later. |
#2 |
I would be interested in some of the larger caps if you can post some pics.
Thanks.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
representative pic as promised.
#4 |
mcintosh caps sold
4 c-d caps sold |
#5 |
bump.
#6 |
I will buy that iec entry module. Send me an email
#7 |
obo on all parts...
#8 |
diyAudio Moderator Emeritus
Hi Josh. What are the dimensions (diameter and length) of the CD caps? Do they have solder or screw terminals on the top?
Brian |
#9 |
c-d caps ... 2 3/8 tall, not incl pins, by 1 3/8 in diam
solder tabs |
#10 |
You've got mail.
Brian |
| Replacing multi-section caps with multiple caps? | Sir Trefor | Tubes / Valves | 1 | 29th May 2007 10:17 PM |
| Paralleling small value caps with large value PS caps | xyrium | Power Supplies | 16 | 14th October 2005 04:06 PM |
| Alps pots vs. TKD pots? TKD worth the extra$$? | G | Tubes / Valves | 11 | 17th August 2004 04:33 AM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| 2KVA Toroids, Caps, Pots cheap | dshortt9 | Solid State | 1 | 9th May 2001 05:11 AM |
| Page generated in 0.11730 seconds (68.62% PHP - 31.38% MySQL) with 11 queries |
