Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
WTB: F4 PCB boards
WTB: F4 PCB boards
Old 20th June 2007, 03:23 PM   #241
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
WTB: F4 PCB boards Send a message via AIM to Peter Daniel
The two pin rectifiers will work too:
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 20th June 2007, 03:25 PM   #242
However, because one of the pins is hanging not connected now, you need to use jumpers between center pad and outer pin. The jumpers install like in a picture below (opposite the white stripes which mark something else). You can also bend the pins and use them as jumpers:
www.audiosector.com
Old 20th June 2007, 03:28 PM   #243
The white stripes mark the spots to install rectifiers in TO-220 packages (like MUR860)
www.audiosector.com
Old 20th June 2007, 03:31 PM   #244
Picture below shows how rectifier board connects to the PS board: use 4 wires for DC, wires from transformer secondaries connect to pads marked A/C (one secondary to one set of diodes, the other to a second set)
www.audiosector.com
Old 20th June 2007, 03:33 PM   #245
The board will also work with all types of 3 pin regulators (two separate footprints for different pinouts), and I will try to explain it later. It's pretty straightforward though, just follow the regulators datasheets and traces on the board
In case of TO-220 diodes, their pins can be used as jumpers to connect directly with traces to capacitors.
The short lines in bottom layer mark where you should cut the traces when 4 pin Jensen caps are being used (to get full advantage of 4 pin configuration).
www.audiosector.com
Old 20th June 2007, 03:51 PM   #246
Westley is offline Westley  United States
Default F4 PCB Boards
Peter,
I received the boards today. Thank you. Great job!
They turned out well - one channel is almost finished except for the outputs.
Old 20th June 2007, 03:53 PM   #247
Let's hope I didn't do any error with amp boards; I didn't have a chance to test them out yet...
www.audiosector.com
Old 20th June 2007, 05:13 PM   #248
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Let's see if you can power up a board and test it out
Do you have a part number you may share with us for the 3 pin diodes that you used in the first post with them soldered to your boards ?
P.S good work
Old 20th June 2007, 06:10 PM   #249
Those would be MUR3060WTOS-ND
www.audiosector.com
Old 21st June 2007, 01:26 AM   #250
Looneytunes is offline Looneytunes  United States
Thanks Peter.
WTB: F4 PCB boardsHide this!Advertise here!
L/R Boards and Matched IRFP240 Boards for Aleph/ A-X lgreen Swap Meet 7 25th August 2009 04:56 AM
FS: Conrad Heatsinks;.... 'PASS' B1 boards w/JFETS;...... F4 AMP & PSU boards cowboy99 Swap Meet 5 25th August 2009 02:39 AM
Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips analog_sa Swap Meet 4 14th March 2009 05:29 PM
WTB: F4 boards Gluca Swap Meet 2 10th March 2009 07:49 AM
FT: Pass boards for P101 boards bjefferys Swap Meet 1 26th March 2006 07:39 PM
