I have some parts for sale:
-4x pcb for a LM3886 standard application including power supply circuit, 85x80mm
professional epoxy pcb, green painted, single sided, solder mask, position print, tinned, 5 Euro each
-several electrolytics fitting in above boards
Philips 10000uF/40V 85°C 10mm snap in, 4 Euro each
-2x LM3886TF, 4 Euro each
-2x toroids, encapsulated, 120VA prim. 2x110V sec. 2x22V, 5 Euro each
-2x used power supply boards, 100x80mm, equipped with rectifier KBU8B, 2x10000uF/35V, 2x4.7uF MKT bypass, 4 Euro each
-2x used boards equipped with LM3876, 70x40mm, rewired to differential amp, gain=10, 5 Euro each
-electrolytics Philips 1000uF/400V, 105°C, 105x40mm 4 Euro each
Jürgen
Jürgen
