Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
ATI Research Flagship Amp Case
Old 16th March 2007, 08:01 PM   #1
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Default ATI Research Flagship Amp Case
ATI Research Flagship Amp Case (model no. ATI-639M)
This is one beautifully built case. The construction is amongst the best I've seen with:
- All anodized aluminium construction with 6mm thick brushed faceplate
- 4mm Alu U-section for mounting multiple heavy toroids (it will accomadate 4x500VA or 2x 1000VA easily.
- Heatsinks are predilled to allow upto 20 pairs per channel of TO3 or whatever they're called. This would be an excellent case to build a 100w class A design.
- All other panels are 2mm thick black anodized
- 2 huge heatsinks rated at 0.075cw(convection NOT forced) running down the flanks of the case
- Spun solid Aluminium power switch and 6 solid alu feet - no plastic here at all.
- Acres of room inside, giving lots of options and flexibilty of routing and component spacing.
The case is mint but I have drilled and tapped 8 holes in each heatsink, there's that much real estate on the heatsinks that it hardly matters though but I mention it so as to be honest as possible.
The rear panel is all professionally machined and I've taken the liberty of fitting Neutrik XLR mounting style gold plated RCA's, the rest such as the IEC, fuse holder, binding posts etc. will need to be supplied by you. The rear panel also has plenty of room left over and could easily be modified to allow for up to 6 channels - its has all the holes required for 2/4 channels at the moment.
I paid 320 including shipping a few months ago for this amazing case. Looking for 200 including shipping within the UK.
EDIT: Dimensions are:
- Front plate: 482.60 w (19") X 165.10 h (6.5")
- Internal size : 355.60 w (14") X 162.56 h (6.4") X 596.90 d (23.5")
Manufacturer Link:
http://www.atiresearch-anodized.com/
http://www.atiresearch-anodized.com/ATI-639M.html
The more you know who you are and what you want, the less things will ever be the same.
Old 16th March 2007, 08:02 PM   #2
ShinOBIWAN's Avatar
And photo's:
Old 17th March 2007, 06:02 PM   #3
ShinOBIWAN's Avatar
Reduced to 170 inc postage.
Old 18th March 2007, 08:28 PM   #4
wigginjs is offline wigginjs  United States
wigginjs's Avatar
Shipping to USA zip 29201?
Old 18th March 2007, 09:09 PM   #5
ShinOBIWAN's Avatar
130 using UPS. The weight is 18kg but size of the box is large (70cm x 55cm x 23cm).
I don't expect this will be really a viable option for those overseas.
Old 19th March 2007, 04:28 PM   #6
housing is offline housing  Hong Kong
A really nice looking and outstanding case.
If I were in UK, I'll take it.
Old 19th March 2007, 08:13 PM   #7
hooha is offline hooha  Canada
hooha's Avatar
It would be if the price included shipping...
Let's keep this fine looking unit at the top.
Breaking speed records - http://www.mach5audio.com
Old 19th March 2007, 09:29 PM   #8
dr.strangelove3 is offline dr.strangelove3  Netherlands
dr.strangelove3's Avatar
I love that case! But the 0.075C/W. Is that correct? This post states it is 0.279C/W per side.
Old 19th March 2007, 09:35 PM   #9
ShinOBIWAN's Avatar
No idea, that was the figure Arthon (the guy at ATI) gave me when I was asking questions prior to buying the case.
Old 19th March 2007, 09:39 PM   #10
ShinOBIWAN's Avatar
Not had any interest at the asking price and I'd rather keep it than let it go for peanuts. So I'll withdraw this from sale and hold on to it until I get bored of tripping over it again.
ATI Research Flagship Amp CaseHide this!Advertise here!
ATI Research Amp Case ShinOBIWAN Swap Meet 3 28th November 2006 05:22 PM
gr research ob5 gary h Multi-Way 0 6th October 2006 01:40 AM
help on research naga Everything Else 1 7th January 2006 05:09 PM
FS: Klipsch RC-7 Flagship Center tunemanjjw Swap Meet 0 20th December 2004 01:13 AM
flagship alpine (scanspeak) car speaker set Jean Everything Else 3 13th January 2003 11:54 AM
