| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hi all!
I own a pair of Sennheiser H500A and they require a stereo 2.5mm plug to 3.5mm plug cable. I need it at least 5 feet in length. Anyone got one they can sell? Anyone make one? Anyone fix the one I have? Know where I can get one? Thanks! |
#2 |
If you have a soldering iron....it would be really easy to mke one.
Also - 3.5mm plug to 3.5mm plug cables are quite common. And you might be able to find a 3.5mm to 2.5 mm adaptor to use with it.
Regards Fin |
#3 |
The problem is- I have an adapter. But it doesn't fit into the Headphones.
The current cable that doesn't work was fixed by myself, but it seems there is a cut or a tear somewhere in the ground wire- all I can hear is low volume crosstalk and static. I found replacement cables on the Sennheiser site- I may just have to buy them there. They are pretty cheap anyways- only 8$ + shipping. |
#4 |
You should probably check continuity by connecting a multi-meter to both plugs. Then check that there is no continuity between the signal and ground parts of the cable by connecting the muti-meter to the separate sections of the plug.
Regards Fin |
#5 |
I already checked that- On the original cable their was no continuity between the grounds, everythign else was fine.
So I felt the 3.5 plug end and the plug was loose- cut it open and sodered on a new end after removing the varnish protecting the wires. Still no continuity between grounds, and again everything else is fine. |
#6 |
Well - It looks like you have exhausted all of the possibilities....unless you feel like making the cable shorter and shorter until you eliminate the damage....but that might result in a very short cable depending on which end you start at......
You could also use your existing plugs and just replace the cable with something similar from your local electronics store.....maybe even something better than the standard one. But then...we are just talking about $8.
Regards Fin |
| Thread Tools | |
| Where to get IEC Chassis Plug? | ervington | Parts | 12 | 4th October 2006 04:14 PM |
| soldering hifi speaker cable into 1/4 plug | saifq | Multi-Way | 3 | 19th June 2005 09:48 PM |
| Where to get a 25 pin plug? | Jye | Parts | 5 | 14th February 2005 05:26 AM |
| What DIP plug to use for a daughterboard? | leadbelly | Parts | 1 | 27th October 2004 08:53 AM |
| plug for amp | karma | Everything Else | 12 | 24th April 2004 08:53 PM |
| Page generated in 0.13661408 seconds (78.71% PHP - 21.29% MySQL) with 10 queries |
