| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Power went out as last night in a weird half voltage pulsating kinda way.
Scary part: One of a kind Bruce Moore Pre MFA Lumiscence tube Preamp, three chassis. This is (likely-as far as I can figure) the prototype unit that Bruce and whomever used to 'work out' the designs of the MFA preamps. This is the 'no holds barred' original 'design work-proofing' unit. It is called, by Scott Frankland, the "Venusian' series. One of a kind. There were others, I surmise, from the conversation, but maybe not identical. Who knows. It is now passing DC. It was built, with NO seriel numbers, of course. Properly labled on the front, but NO MFA markings, just the controls. Recognisably a MFA unit. This the bulk of this information came from a conversation with Scott Frankland, previously the F in MFA. (Moore Frankland, and Associates) Needs repair. I'm the one to do it, likely. 1)The fun part, relating the whole mess to a an insurance adjuster. The preamp, passing it's bits of DC (it can pass 100V p-p!- octal tube preamp!)..dutifully sent that signal to my power amp: A highly modded Belles 450, with 300,000uf of capacitance, and a will to use it, like waving a shotgun around the room. It can pass DC at +/- 90V, without even blinking. It dutifully did so. I've got DC offset in the power amp, as well, which means somethings amiss, possibly a blown output fet, which are the now unavailable 2sk135 and 2sj50 hitachi fets. There are NO internal pots of any kind in a belles 450, the DC stability-offset counts on the unit having perfectly matched sets of outputs. The best scenario. Build it right-or stay home. But pricey to fix, when the fets are not available. They are, but the price is sky-high. 2) Try to present that nightmare to an insurance adjuster. Next on the block: A pair of older prototype speakers, which took 6 months to get the crossover right. THey used peerless csx145wr2608 drivers, 4 of them. MTM design, with a custom vifa horn loaded tweeter. Those woofers, of course..are not available. The insurance adjuster and/or technician involved in the assessment, needs to sign a NDA, before they are even allowed to set eyes on the things. Let alone being allowed to take them apart. That is strictly forbidden, NDA, or not. 3: try relating that to an insurance agent. And now...I have no tunes in the house. And I listen to tuneage, while I am awake and in the house, period. Silence, I guess. For a while. And an insurance battle too. Any suggestions?? Good morning! How's your day going?
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#2 |
Bump!
Still looking for a set of 4 CSX 145's!!
#3 |
Still looking for a set of (4) CSX 145's. Will pay. For example, if you had a set of NHT speakers that used that model, and I had to pay to buy the functional pair..I'd buy them. Why?
It's a set of MTM stand mounter's..with a custom horn loaded tweeter, the best crossover I've ever done, and 91-91.5db efficiency. These speaker really kick ***, at the same time they had stunning dynamics-excellent phase alignment. Purely a stroke of luck and two years of grinding my teeth getting the crossover right. I'd like to hear them again. Also, the box design is unique and unrepeatable.
#4 |
Do you have the six digit Peerless part number that is on the back? They sound like 850108s.
http://www.tymphany.com/files/products/pdf/850108.pdf There were two different CSX145 drivers used by NHT. One is an NPT-11-080-1, the other is an NPT-11-081-1. Both are custom drivers, but are based on the 850108. Go here for photos and specs: http://home.comcast.net/~jhidley/index.html Specs for the drivers are located in the spreadsheet located at the top of the page. Additional specs are located in the link just below the pictures. If you had 850108s, then the NPT-11-081-1 driver will be closest.
Jack Hidley ACS |
#5 |
Try some post later in this forum section, there is some 2SJ50 / 2SK135 NOS for sale.
I've bought 2 pair for $24 + shipping if I can remember..... If your amp is well designed, you MUST have : - 2 fuses per channel (on each 2SJ and 2SK branch) : might add it - A DC protection (relay) on the output : some kits are available and can be added externaly I've got an old amp using this FET and no problem with this protection Edit : this is the post Obsolete transistors 2SK135 / 2SJ50 |
| B&W power claims | AndrewT | Everything Else | 4 | 10th June 2009 10:07 PM |
| Home Insurance | scooby300 | Everything Else | 8 | 18th October 2007 10:18 PM |
| DIY Amp / house insurance / fire ? | Brian Guralnick | Pass Labs | 19 | 27th October 2003 09:28 PM |
| Insurance for DIY | seangoesbonk | Everything Else | 1 | 14th July 2002 08:58 PM |
| Page generated in 0.10489 seconds (77.26% PHP - 22.74% MySQL) with 10 queries |
