1)
1kVA 43-0
1kVA 0-43
The two need to be used together for 43-0-43 at 2kVA. New.
2) 800VA 56-0-56vac 2 each. Used in the Forte Model 3 power amp. Used.
3) 800VA 52-0-52vac 1x each Used.
4) 40-0-40vac 360VA x2 each. Used pull outs from Adcom 545 100wpc amps. They are sealed cans.
5) 60-0-60vac 675va Adcom 555 pull out. Sealed/canned. 1x
1kVA 43-0
1kVA 0-43
Some sold, listing other items
1) Plitron 1kVA 33-0-33 used but excellent cond. $90
2) 800VA 56-0-56vac 2 each. Used in the Forte Model 3 power amp. Used. $60 each
3) 800VA 52-0-52vac 1x each Used in some electrocompaniat Amplifier. $55 each
4) 1kvA 65-0-65 toroids unused/new $75 eac, I have 2
5) 60-0-60vac 675va Adcom 555ii pull outs. Sealed/canned. 5x $65
6) 60-0-60vac 800VA New unused Avel's x2 $90 ea
DreadPirate said:Also interested in the 40-0-40 if other party backs out. You don't list a price, how much? Shipping at cost? Thanks.
Other party paid, but if anything happens I will post an update. Shipping at cost yes, but might add cost of packing material if I find none at home thats reusable.
No longer pursuing the 40-0-40. Need 40vDC, not AC....Duh.
True.... but the larger Adcom with 60-0-60, wire the prims in series, that will give you 30-0-30... thats about 41vDC per rail...
running a 220Vac transformer at 110Vac will reduce the VA rating by about half.True.... but the larger Adcom with 60-0-60, wire the prims in series, that will give you 30-0-30... thats about 41vDC per rail...
Expect the 675VA rating to reduce to ~350VA.
how much for the 60-0-60 adcoms or the plitrom shipped to OZ??
I'd say you goto usps.com and calculate shipping to your satisfaction. Each toroid will be about 13-16 lbs and add 2-3lbs for packaging.
Shipping from Indiana IN 46256.
Hope this helps.
