Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Adcom 535 II amp parts...
Old 12th July 2006, 03:52 PM   #1
Stuart Easson is offline Stuart Easson  United Kingdom
Stuart Easson's Avatar
FS: Adcom 535 II amp parts... Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
Default FS: Adcom 535 II amp parts...
Hi All,
Found more stuff that I am unlikely to use anytime soon...
A pair of amp modules from an adcom 535 II, plus the case.
These modules do NOT have the original heatsinks attached, actually they have half, the heatsink was cut off to allow a low profile installation.
The distortion and thermal shutdown LEDS are attached.
IIRC they were supplied with +/- 55v, with 150-200va transformer per channel, ~5600uF per rail, per channel.
Both have the additional output transistors that would have been present if the modules had originated in the 545 II.
Both have been tested and work, apparently perfectly. I have not performed measurements to verify offset or bias levels etc. These have been stored for years and as such should be checked to make sure the adjustments are set correctly.
Very conservatively rated at 60w RMS, with the additional transistors and a bigger power supply they are used to deliver 100w RMS in the 545 II.
$60 for the pair. Plus I'll include rectifiers and caps to allow a constructor to get a headstart on the power supply.
I also have the case they were removed from, but all it's internals have been removed : $20
payment via any normal means but nothing leaves until payment has cleared...I'd prefer paypal.
Shipping is at cost to anyplace you are prepared to pay for.
Pictures to follow...
Old 12th July 2006, 04:21 PM   #2
Default picture of one of the amp modules...
FS: Adcom 535 II amp parts...Hide this!Advertise here!
What parts in input board of Adcom 555 II BLOWN Solid State 0 8th October 2008 08:43 PM
Adcom 555 repair parts swap ? digital desire Solid State 0 26th November 2006 11:21 PM
Source for Adcom GFA-565 Monoblock Parts tfong Solid State 4 10th October 2006 08:42 PM
Adcom GFA-585 Parts Needed wilsonmw Parts 2 14th July 2005 06:09 PM
Adcom GFA-555 parts amp on Ebay... Apogee Parts 0 10th July 2002 01:38 AM
