Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: pair of new Lambda TD-15S sealed box woofers
Old 31st May 2006, 03:45 AM   #1
taloyd is offline taloyd  United States
Post FS: pair of new Lambda TD-15S sealed box woofers
hello,
I have two unused (unmounted) Lambda TD-S series 15" woofers. I was saving these for a project that has changed directions so many times that they are no longer needed (in the final ultra-super-mega iteration of the Speakers of Doom).
Asking $350 shipped in the continental USA for both. These drivers are considered an upgrade to TAD drivers... they have a legendary reputation among those who have them.
Specs (from the now-defunct Lambda site):
Fs 22.8 Hz
Qms 3.87
Qes 0.41
Qts 0.37
Vas 467 Liters
Cms 0.45 mm/N
Mms 108 grams
Sd 855 cm2
Rms 4 Kg/S
Bl 14.1 T/m
Re 5.3 ohms
Z 8 ohms
Le 0.3 mH
Pe (nom) 300 Watts
Pe (max) 500 Watts
Pe (transient) 1000 Watts
"no" 1.31 %
1WSpl 93.4 dB
Air Gap 18 mm
VC Length 38 mm
Linear Xmax 10 mm (peak)
Mech Xmax 20 mm (peak)
Part# TD15S
Size 15"
Motor TD (overhung)
Magnet 120oz (3.4Kg) Ceramic 5
VC diameter 51mm
VC Former Black Anodized Aluminum
VC Wire 2 Layer Copper Roundwire
Basket Cast Aluminum 12 Spoke
Cone Paper Based
Cone Profile Curvilinear
Surround Doped Foam, 2 layer treatment
Dustcap None - Phase Plug
Spider Medium stiffness Nomex
Faraday Copper
Pole Vent No - Phase Plug
Terminals Gold Plated Binding Posts
Weight 23lbs
Old 3rd June 2006, 01:19 AM   #2
eparson is offline eparson
ygm
Old 5th June 2006, 02:45 AM   #3
Default Sold!
Hello,
The woofers have been sold!
thanks,
-Tal
FS: pair of new Lambda TD-15S sealed box woofersHide this!Advertise here!
FS or trade 1 pair Dynavox 6.5" woofers, 1 pair of Tweets.. JCoffey Swap Meet 4 20th September 2006 04:56 PM
small, sealed enclosure using Silver Flute woofers Bose(o) Subwoofers 5 31st December 2005 05:03 PM
FS: Lambda Acoustics TD12S (faraday) woofers pkpickard Swap Meet 5 18th December 2004 09:56 PM
Lambda TD15X woofers thylantyr Multi-Way 3 10th September 2002 07:45 AM
Lambda TD15H woofers JohnR Swap Meet 1 23rd May 2002 09:09 PM
Copyright ©1999-2017 diyAudio
