Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 26th May 2006, 03:40 PM   #1
cartman's Avatar
Send a message via ICQ to cartman
Default Remote stepped LADDER NETWORK attenuator w/ source selector
For sale:
Remote volume control board incl. 4 source selector, using relay (Halcro also use relay on their DA10 pre amp) switching two set of 1/4W RA resistor (made in USA - ladder network).
1dB per step, attenuate from 0dB to -88dB, input impedance is near constant, using 1/4W RAresistors, with four input relay and display, seperated voltage regulator board, with remote control handset, dual mono design, left and right channel fine adjustment.
Impedance: 100K
Source: 4
Mute: Yes
Display: BLUE LED
IR Remote: Yes
I'm asking only $150 (world wide shipped)!!!
board size: L 180mmX W 45mm
dsiplay board: L 230mm X W 52mm
Old 26th May 2006, 03:42 PM   #2
cartman's Avatar
the resistors
Old 27th May 2006, 08:50 AM   #3
cartman's Avatar
resistors: RA High-Grade Audio (made in USA)
gift: power transformer
extra: aluminium case front ;-) 10mm!!
Old 27th May 2006, 10:46 AM   #4
cartman's Avatar
sorry it's only 5-6mm
Old 27th May 2006, 10:47 AM   #5
cartman's Avatar
more
Old 27th May 2006, 10:49 AM   #6
cartman's Avatar
again
Old 27th May 2006, 12:22 PM   #7
> Impedance: 100K
How can we determine if it will fit work with a preamp of unknown impedance?
thanks
Old 27th May 2006, 07:29 PM   #8
cartman's Avatar
Hi Rick,
this module does work like a 2x100K log normal pot....and a 4 sources input selector
Nothing special...
Old 27th May 2006, 07:40 PM   #9
cartman's Avatar
output impedance is near constant (50K)
Old 28th May 2006, 08:37 AM   #10
cartman's Avatar
sold
Where to find RF remote stepped attenuator? Bgt Analog Line Level 8 13th February 2009 01:53 AM
Cheap stepped ladder attenuator. Coarse and fine. OzMikeH Parts 2 1st January 2008 02:51 AM
My DIY Digital Preamp/Source Selector w/ LCD & Remote Mr.Radar Chip Amps 3 8th February 2006 12:26 PM
Remote Controlled Stepped Attenuator Miniwatt Tubes / Valves 4 27th January 2006 06:22 PM
Stepped Attenuator and Selector Switch Bryan Tubes / Valves 2 18th February 2005 07:14 PM
Page generated in 0.11099 seconds (79.66% PHP - 20.34% MySQL) with 11 queries
