Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 11th March 2006, 02:51 AM   #1
Audio Junkie
Zero Cool's Avatar
Default Wanted: Long control shafts & Bushings
I am trying to find a source for some control shafts and bushings.
I want to mount a pot near the back of a chassis and have a long shaft extend through from the face plate. i see this done in preamps all the time but where do you buy the shafts and the bushings that mount to the front panel???
Old 11th March 2006, 05:50 AM   #2
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Make your own.
Grab a length of 6mm aluminium tubing from a hobby shop
Solid coupling from RS Online Cat No 509-703
Front bush from an el cheapo banana socket (drill bore to suit) glued into hole in front panel
Banana socket
Old 12th March 2006, 03:12 AM   #3
PierreQuiRoule's Avatar
Default Front bush
Alternatively, you can purchase plastic "flanged sleeve bearings" from McMaster-Carr. Drill a 5/16 whole in the face plate, put a sleeve in, and then your 1/4" shaft in the bearing. Positioning the flange between the face plate and the shaft knob prevents the sleeve from sliding out of the face plate hole.
Pierre
Old 12th March 2006, 05:57 PM   #4
Audio Junkie
Zero Cool's Avatar
Well i suppose in true DIY fashion, i could diassemble some pots and just use the chassis of the pot as a front bushing. hadnt thought of that. Its ok, i managed to find some on eBay. but i was hoping to find a commerical source for them.
Zc
Old 12th March 2006, 09:24 PM   #5
coils is offline coils  United States
I used 1/4" ground stainless and shaft couplers from McMaster Carr, for bearings, I used "Spyralign" Acetal Press Bearings from Small Parts Inc. They are made for sheet metal applications. and are available from 1/8" to 1/2" I.D.
http://www.smallparts.com/
http://members.dslextreme.com/users/...s/BZLSopen.jpg
Thad Howard
Coiler
Old 12th March 2006, 10:01 PM   #6
Audio Junkie
Zero Cool's Avatar
OHHHHHH theres gold there! thanks!
Old 12th March 2006, 11:38 PM   #7
Hardware stores in these parts always have those little plastic boxes above the bins that hold all the fasteners. All sorts of goofy stuff in them... clevis pins, fancy machine washers, cotter keys in every imaginable material, nylon screws, etc.
Anyway, there should be a little box of oil-lite bushings with all sorts of ID's and OD's... one of my favorites spots, also nylon bushings, and fancy allen heads. Not cheap but cheaper than McMaster for certain.
Check your local store.
Why delay gratification?
Old 13th March 2006, 12:26 AM   #8
Default Email me
I have am extra set or two of shaft extenders. They have double u-joints, and slide to fit to length.
The collars fit 1/4" shafts, have double set screws. They can be cut down if shorter is needed, but are 6" long and extend to 9".
The 3/8 x 1/4 bushings should be available at any True Value hardware store. But I have some of those also.
George
Wanted: remote control for Philips CD 850MKII 123chris Swap Meet 0 9th April 2008 09:03 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 11:53 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 01:06 PM
Bushings for rack-mount equipment tiroth Everything Else 2 25th June 2002 05:49 PM
Page generated in 0.11182 seconds (76.74% PHP - 23.26% MySQL) with 11 queries
