Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 11th November 2002, 09:06 PM   #1
Bill Fitzpatrick's Avatar
Default Grayhill 7pole 20 position rotary
I have a few extra Grayhill 7 pole, 7 deck, 20 position rotary switches for sale at $25/ea.These are Mil Spec sealed switches with a 1/4" flatted shaft. I can take paypal. Add $3 for US shipping.
Old 11th November 2002, 10:20 PM   #2
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Is this a shorting or non-shorting switch?
Old 12th November 2002, 12:07 AM   #3
It's non shorting. They are brand new. Switches like these are well over $100 in the distributors catalogs.
I tried to attach an image before but it didn't take.
Old 12th November 2002, 03:25 AM   #4
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
will you take paypal?
Brian
Old 12th November 2002, 04:19 AM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
What could they be used for, if they are non shorting?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th November 2002, 04:28 AM   #6
BrianGT's Avatar
does non-shorting just means that it breaks connection before changing to the next switch setting, in comparison to shorting, which connects before disconnecting. Is this correct? So, non-shorting switches create a bad "pop" when channels, right? Is there anyway to avoid this problem?
Brian
Old 12th November 2002, 04:39 AM   #7
Shorting switches are used for volume control, and when changing level you would get uninterupted signal without pops.
Non-shorting switch can't be used as a shunt element in volume control, because it brakes to ground connection and ea. time it creates maximum signal level.
I imagine the only way to change it for shorting type switch is to change the wiper. But there are 7 of them and it's almost watch makers precision job.
Nevertheless, those are fine switches and I'm seriously considering getting one for myself.
www.audiosector.com
Old 14th November 2002, 10:06 PM   #8
Just a few of these switches left. If you want one, now's the time.
Old 18th November 2002, 09:58 PM   #9
BrianGT's Avatar
Could you just wire the ground connection to the switch differently to get rid of this problem? You would still get an interrupted signal, but you could get rid of the pops. You could tie the ground to the lowest volume level of the switch. Would this work?
Brian
Old 19th November 2002, 12:50 AM   #10
The problem is that when the switch pole is in between positions and making contact with nothing, there is no shunt element in the circuit. The signal volume shoots up to maximum every time you rotate the switch one position.
It is possible to switch the series resistance, as opposed to the shunt resistance but many purists would be aghast at this idea because it put all the resistors and as many solder joints directly in the signal path, so they say. They do forget, however, that if this were a shorting switch using the typical configuration, all the resistors and solder joints are still in the signal path.
Whoever it was that first said than a shunt to ground is not in the signal path has been watching too much television.
Optical Rotary Encoder Volume Control unit using the Grayhill 62P DJ Exprice Everything Else 17 1st January 2008 08:50 PM
FS 2x 40000uf 50V cap banks, grayhill 4deck, 2pole, 5pos rotary switch. Illusus Swap Meet 4 22nd April 2005 09:54 PM
ITT 30 position rotary switch WALTER BURKHARD Swap Meet 3 21st December 2004 12:22 AM
Grayhill 7 pole 20 position rotary switch Bill Fitzpatrick Swap Meet 25 5th May 2004 04:45 AM
FS: Grayhill 6-position PCB mount rotary switches antness Swap Meet 19 3rd February 2004 02:46 PM
Page generated in 0.08824 seconds (84.05% PHP - 15.95% MySQL) with 11 queries
