Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Grayhill 7pole 20 position rotary
Old 19th November 2002, 02:51 AM   #11
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Grayhill 7pole 20 position rotary Send a message via AIM to Peter Daniel
One could use it like that: fixed resistor to ground and switched series element. Since only one resistor is always connected, purists don't have much to complain and it can be used for up to seven independent channels. Also, no signal volume shoots up to maximum every time you rotate the switch, because shunt resistor is connected permanetly.
To order kits contact me through forum mail.
Old 19th November 2002, 03:16 AM   #12
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Wouldn't that limit the range of your volume control, and if not, wouldn't it still get damn loud when it has no connection when switching? That is what I was thinking of earlier when I posted, but I don't see how it would work well?
Brian
Old 19th November 2002, 03:31 AM   #13
I don't think it would limit the range any more than fixed series element and switched shunt resistor (this is what I'm using currently). If no conection when switching, there is no signal at all because of an open circuit.
Old 19th November 2002, 12:54 PM   #14
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default ROTARIES
And this is exactly how I build these for attenuating the signal in a tube preamp.
When the next stage uses a fixed gridresistor to bias that tube it is important not to shunt it since that would change the tubes' operating point.
Since you put only one resistor and one contact in series with the signal it is also the most "purist" approach.
See also:
http://www.diyaudio.com/forums/showt...&threadid=6847
Ciao,
Frank
Old 19th November 2002, 01:07 PM   #15
One other thing; it may seem that 20 positions might not be enough, but I'm using 24 positions Elma and in fact, I'm mostly switching between 6 positions anyway.
Old 19th November 2002, 01:15 PM   #16
fdegrove's Avatar
Default POS USED.
Hello,
Yep.
And that is where I spend money on resistors.
Ciao,
Frank
Grayhill 7pole 20 position rotaryHide this!Advertise here!
Optical Rotary Encoder Volume Control unit using the Grayhill 62P DJ Exprice Everything Else 17 1st January 2008 08:50 PM
FS 2x 40000uf 50V cap banks, grayhill 4deck, 2pole, 5pos rotary switch. Illusus Swap Meet 4 22nd April 2005 09:54 PM
ITT 30 position rotary switch finwbu Swap Meet 3 21st December 2004 12:22 AM
Grayhill 7 pole 20 position rotary switch Bill Fitzpatrick Swap Meet 25 5th May 2004 04:45 AM
FS: Grayhill 6-position PCB mount rotary switches antness Swap Meet 19 3rd February 2004 02:46 PM
