| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
I recently got my hands on a big DC power suppy. It's a Kepco RCW 48-32k, rated for 32A at 48v. I'm not really sure what to do with it, or if it could be used as the power supply of an audio amplifier. I know the voltage is adjustable between 30 and 52 volts. Here's a link
http://www.kepcopower.com/rcw.htm The specs are: * Wide range a-c input (85-264V a-c). * 350W and 1500W (not 750W) models have current sharing for N+1 paralleling. * Overcurrent limiter, square type. * Undervoltage detector, (350W~1500W models) shuts down RCW if overload persists for more than 40 seconds. * Overvoltage protector - immediate shutdown (reset by removing mains power for ‰ 40 seconds). * Trimmable output voltage. * Remote on/off logic. * Alarm flags; OV, UV, thermal, fan (350W~1500W models). * Power fail alarm (input power failure) (350W~1500W models). * Output overvoltage and thermal protection indicator (red) (350W~1500W models). * Output low voltage indication (red) (350W~1500W models). * Fan alarm indication (red) (350W~1500W models). * Remote error sensing: 0.15V for 3.3V models, 0.25V for 5.0V models, 0.4V for 12-48V models. * UL/CSA/TÜV safety approval EN 60950. * Certified per MIL STD 810E. * DIN Rail mountable The list price at Kepco is $1435. Any ideas on what this is worth? Can it be used in a DIY amplifier project? I'm on the fence between selling it and buying a completed amplifier, or trying to build one. Dan |
#2 |
Master Burner
For power amp you would normally use dual power supply. This appears to be single supply.
#3 |
"List price on Kepco is $1435"
If its new, you ought to be able to get %25-50 of that... Not really the right thing for an amp...
#4 |
Not right for an amp... that's too bad. Maybe I can ebay it for $300. Thanks for the feedback.
Dan |
| Intrest Check: 120w @ 8ohm Tube Buffered LM3875 Amplifier | rhysh | Chip Amps | 189 | 30th May 2010 07:54 AM |
| Intrest Check : Pretty Simple Digital Preamp / Volume Control | rhysh | Chip Amps | 69 | 20th December 2008 07:14 PM |
| Kepco 615B Bench Supply pix | jackinnj | Tubes / Valves | 1 | 1st May 2004 04:49 AM |
| Page generated in 0.09188 seconds (70.51% PHP - 29.49% MySQL) with 10 queries |
