Although I have obtained a PCB from ChipAmp.com, I still need the assorted parts to go with it.
The parts I need:
2x 24-0-24 transformers. It's a dual-mono setup.
Components for amplifier boards
2 LM3886TF
4 22 kohm 0.5w compact metal film resistors
2 10 kohm 0.5w compact metal film resistors
2 1 kohm 0.5w compact metal film resistors
2 680 ohm 0.5w compact metal film resistors
2 2.7 ohm 2w metal film resistors
6 100 uf 50v Panasonic FC
2 47 uf 50v Panasonic FC
6 0.1 uf BC polypropylene cap
Components for power supply boards
4 10000 uF 50v Panasonic TS Capacitors (35mm x 30mm low profile)
16 MUR860 On Semiconductor Diodes
4 2.2 kohm 2w metal film resistors
4 1 ohm 2w metal film resistors
2 blue LEDs
2 1N4004 diodes
2 10 uF Panasonic FC Capacitors
The parts I need:
2 LM3886TF
2 blue LEDs
2 1N4004 diodes
Spasticteapot said:Although I have obtained a PCB from ChipAmp.com, I still need the assorted parts to go with it.
The parts I need:
2 LM3886TF
2 blue LEDs
2 1N4004 diodes
sorry, but...
Thanks, that's made my afternoon.
