I have the following for Sale:
(U) = Used (N) = New
1 - Linn LK-1 Preamp Potted Transformer & encased (U)
1 - Linn K-5 Phono Cartridge (U)
2 XLR Chrome Jacks - Female (1 is N)
1 XLR Chrome Plug - Female (N)
2 (qty) Toroidial Transformer 115V/230V Primaries 1 - 8.5VDC 1.1A Secondary & 1 - 14.9VDC 0.53A (N)
Miller #5717 Toroidial Inductor (N)
Miller #5722 Toroidial Inductor (N)
3- Sanken A1386 Power Transistor (Used from NAD 304) (U)
3 - Sanken C3519 Power Transistor (Used from NAD 304) (U)
The above are complementary PNP & NPN pairs
4- NEW ONSEMI (Motorola) TIP35C TO3 Power Transistor (N)
4-NEW ONSEMI ( Motorola) TIP36C TO3 Power Transistor (N)
4- NEW 2N3055 TO3 Power Transistor (N)
1 - NEW MPS2955 TO3 Power Transistors (N)
1- Corcom 10A EMI Filter#10VK1 (Solder Lug type) (U)
1- Delta Electr. 3A EMI Filter Model #03DFFG33R (3 Prong AC Plug)(U)
2 - Mallory LP type 15000uF 16VDC 105C Capacitor 35X30 mm(U)
2 - UCC LXG type 10000 uF 35VDC 105 C Capacitors 35X30 mm(U)
4 -Nichicon CE Type 10000uF 35VDC 105C Capacitors 25X45 mm(U)
2 - Nichicon CE Type 2200uF 35VDC 105 C Capacitors 25X50 mm(U)
1- ICC PSL Type 470uF 200VDC 85 C Capacitor 35X30 mm (N)
3- Nichicon Muse 10000uF 16VDC 85 C Capacitors 18X40 (N)
1- Knob Brushed Aluminum 30mm diameter X 18mm deep
2 - Analog Device AD713AQ Epoxy DIP Quad 14 PIN Opamp (N)
2 Analog Device AD712BQ Epoxy DIP Dual 8 PIN Opamp (N)
3 - Analog Device OP-275GP Plastic DIP Dual 8 PIN Opamp (N)
2- Signetic NE5532AN Pastic DIP Dual 8 PIN Opamp (U)
1 - Analog Devices AD1865 Dual 18 Bit D/A Converter (AA DITB) (U)
Let me know what you are interesed in and I will give you a good price.
If you want a photo of any of the above stuff I will email on request.
Thanks,
Dan
Thanks,
Dan
