Hello Pinkmouse!
Did you change your mind or ?
Heres my collection so far:
I was hoping for your unit to be on the available emty space left on the hdd chassis.
WOW I just hooked up and 8MHz crystal oscillator module to the polygon you sent me and WOW the RPM really went skyhigh I can feel the breeze almost half a meter away. First i thoght it was broken because it would only run it like a hundred RPM, until i finally found the 8MHz oscillator.
My first high speed unit.
Thanx again!
Thanx again!
