Audiosource Amp One 80Watts X 2 (200Watts Mono)
Like new condition and has original box/manual etc. Asking $150 + shipping. Thanks for looking.
• All the high-current output you need with none of the features you don't need
• 80 watts RMS per channel stereo power amplifier with internal bridging
• Torrodial Power Supply
• Stable into 2 ohm speaker loads
• One stereo input and one stereo auxiliary output
• Rear mounted Stereo/Bridged switch
• Truely an unbeatable power amplifier for the price
• 5 way speaker wire binding posts for bare wire or banana plugs
• 80 watts RMS per channel into 8 ohm loads
• 100 watts RMS per channel into 4 ohm loads
• 200 watts RMS bridged into 8 ohm loads
• Total Harmonic Distortion: <0.04%
• Intermodulation Distortion: <0.04%
• Frequency Response: 20Hz-20kHz, +/-0.5dB
• Signal to Noise Ratio: 110dB
• Input needed to reach full output: 0.8v
• Input Impedance: 30kohm
• Headroom: 2dB
• Dimensions: 16.5"W x 2.375"H x 11.625"D
