Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Carver C-9 sonic hologram thingy
Old 19th November 2005, 11:38 PM   #1
Jimmy154 is offline Jimmy154  United States
Jimmy154's Avatar
Default Carver C-9 sonic hologram thingy
Any one want this piece of ****?
http://i34.photobucket.com/albums/d1...4/sonic001.jpg
http://i34.photobucket.com/albums/d1...4/strin004.jpg
http://i34.photobucket.com/albums/d1...4/strin005.jpg
Make me an offer.
Ah ****, those pics suk, but it looks good in reality.
I also have a broken H/K CD 401 and H/K hk200xm tape decks that are not working.
Old 19th November 2005, 11:51 PM   #2
sam9 is offline sam9  United States
sam9's Avatar
Sorry already got one. Would not sell it. It's biggest shortcomming is noise (see below). Of course if one simply doesn't approve of such things there no common ground.
Actually, I got a copy of the schematic and have started to layout a board with good modern opamps in stead of all those RC????s that are esseentially just quad 741's. Also plan to use good quality MKT caps 1% resistors and build a much better power supply. Finally a few other improvements like reed relay switches.
I had the boards almost laid out before a new job and a relocation swide tracked me. The only problem seemed to be that layout exceed the pin limit of the software so I statred over with the idea of making a mother board plus two daughter boards for the sections of the L&R channel s that bare identical.
It will be 6-12 months now before I can get back at it but if it works. I'll post info and maybe Gerbers on the forum.
Old 20th November 2005, 12:02 AM   #3
Jimmy154's Avatar
I have no idea what you said.
Well these words/phrases:
RC????s
quad 741's
reed relay switches
Old 20th November 2005, 02:11 AM   #4
Jim Karr is offline Jim Karr  United States
Question Carver thingy
Does it work? I remember when this thingy first came out. Of course, Bob Carver was the king of hype and attractive copywriting. Even people who didn't own a stereo would want one after reading the ads and the reviews.
I've never heard one. I own a RG Dynamics dynamic range expander circa 1980 or so that works very, very well. After the advent of CD's, the need to expand dynamic range and get rid of motor noise and surface roar (ala LP records) kind of went away. It still makes FM sound very good.
What's the thingy worth? I might be interested.
As for me and my household, we shall serve the Lord. Joshua
Old 20th November 2005, 02:36 AM   #5
sam9's Avatar
Yes they work. If you set it up right. That means positioning the speaker and yourself just so. Even then it does not work with every recording. When it doesn't work it does little harm and in any case has a bypass switch. When the recording is such the results range fom nice to spectacular. Actually I usually find the effect more realistic and listenable than the surrond derived by early Doby ProLogic. PL-II is another mater. Good multi-channel SACD or DVD-A is generally better and seating and speaker positioning is not so critical. The down side is as said noise which may or may not be noticable depending og your system and how loud you play it. Distortion figures are meaningless since by intent the input signal is substantially altered..
I suspect the ambience enhancing software you find with many soundcard derives from the technology. Cross feed circuits on some headphone amps are most likely in the same category. hey are all playing with the distribution of left and right channel information.
Old 12th April 2008, 08:01 PM   #6
Arnold_R is offline Arnold_R  Netherlands
Default Carver holographic
I would be very pleased to know if you would be able to share your schematic with us
i've heard it years ago and was really cray about it
greetings Arnold
Old 4th October 2010, 04:28 PM   #7
ChuckK is offline ChuckK  United States
Default Most interesting...
Make me an offer.
I'd like the C9 if you still have it. How much to ship to Norman, OK 73069?
Thanks!
Chuck K
cmk59@yahoo.com
Those Who Do Not Remember The Past Are Condemned To Repeat It. - Santyanna
Old 4th October 2010, 05:11 PM   #8
Jimmy154's Avatar
I sold it.
Carver C-9 sonic hologram thingyHide this!Advertise here!
new Brand of Hologram Laser (LDGU) LT0H30PA inside by Philips CDM12 and VAM12 mech tiefbassuebertr Digital Source 40 8th March 2016 07:12 PM
Return of the vacuum tube sonic hologram generator thoriated Tubes / Valves 2 9th November 2011 09:41 PM
The Rabbit/Panther Thingy KBK The Lounge 2 11th January 2009 04:25 AM
DRC with that DRC thingy! 5th element Multi-Way 4 4th April 2004 04:46 PM
hinge bracket type thingy meta Parts 7 10th May 2003 07:50 PM
