would someone donate me a pair of tubes? - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 16th November 2005, 01:25 PM   #1
demogorgon's Avatar
Send a message via MSN to demogorgon
Default would someone donate me a pair of tubes?
hey!
i'v been wanting to play with tubes for a long time, to see what all the fuss is about, but never got aroud to buying anything since my funds as a student living away from home are rather scarce.
so i'm making this thread in case someone has a pair of tubes that for some reason isn't going to be used for an amp any more, for me to experiment with, getting to know tube audio!
Insted of throwing them in the litter, send em' to me, so to say
so if anyone do, and wish to donate me a tube or two, I would very much appreciat it!
Marius
Old 16th November 2005, 07:15 PM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
What were you looking for?
I've got hundreds of old tubes lying there, mostly TV, some radio, most used, some broken, some probably pretty good...
/Hugo
Old 16th November 2005, 07:41 PM   #3
dhaen is offline dhaen  Europe
dhaen's Avatar
Maybe we should invite Demostenes to post here.
Arnold is a Norwegian dealer who posts on RAT. The username Demostenes seems to be dormant.
Why not send him an email anyway. Don't forget to ask for sockets to match
Old 16th November 2005, 08:48 PM   #4
rcavictim's Avatar
Just having a pair of tubes and sockets for them is not going to get you much closer to a tube amplifier. I would seriously suggest that you try to locate a vintage Hi-Fi console from the 50's-60's that has tubes. These show up at curb-side here in Canada as trash or may be found at Goodwill and used stores for cheap. You can start by using as-is and then experiment with modifications. The chassis can be pulled out of the large cabinet if desired to save room.
If you want to DIY from scratch old TV sets from the 50's have valuable parts such as power transformers, 5U4 recifier tubes, often 6SN7 tubes that are very, very good preamp and phase splitter tubes for hi-fi use and other tubes of value for hi-fi as well. The power transformers are usually perfectly suited for modest power, high quality tube amp applicaions.
Old 16th November 2005, 09:42 PM   #5
demogorgon's Avatar
/Hugo
why, are there so many different types?
If you have some small, low voltage types lying around...
well, there's the problem with money again, shops rarly give away stuff for free.
I'l send a mail if my quarry isn't resolved i another way though.
why is that? what else is needed?
i do have a fair assortment of various electronics allready.
I'v been into chipamping and a bit of solid state for a while.
thanks for your reply's all!
-Marius
Old 16th November 2005, 10:22 PM   #6
dhaen's Avatar
There are an enormous number of types. A large percentage are useable in some way for audio.
Not many types are useable for low voltage, most need 100V or more.
Demostenes is a regular poster on the RAT newsgroup, so tubes are his passion as well as a business. I'm sure he'll be able to find something for you. Perhaps you could offer the postage.
Well most tubes are just a single or double amplifying element, just as a discrete transistor is. Your chipamps have many transistors inside on package. It is possible to make an amplifier with one tube.
Because tubes are high impedance devices, resistor values tend to be higher and capacitor values lower than transistor circuits. Transformers are regularly used to convert the impedance to a lower value, such as to drive a loudspeaker.
Old 16th November 2005, 11:38 PM   #7
Heisann!
What is it that you have in your fair assortment of electronics?
Transformers.. High Voltage rectifier diodes.. H.V. psu capacitors..
And what is it that you want to build? A tube-pre-amp for your chip-amp? Or something else?
Here is an example of a very simple cheap to make amp:
http://music-club.rutgers.edu/headfonz/6EM7-amp.html
Hilsen
Peter (også fra det iskalde nord)
Old 17th November 2005, 08:08 PM   #8
demogorgon's Avatar
dhaen, thanks for your reply.
You confirm the general impression i allready had conserning tubes.
and i will contact Arnold to se if we can perhaps come to a agreement.
Originally posted by Peter M.
Heisann!
Hilsen
God kveld!
A fair assortment of electronics would be what i'v gatherd from dead articles, bought and scavaged through the 3 years i'v been into electronics, quite a lot.
rectifiers i have tons of, HV caps i can rip out of computer switchmodes or TV's. transformers such as output irons i dont have, but i'm not planing to try making anything more than perhaps a buffer stage, or perhaps a small gainstage for a preamp or a headphone amp. however, mains tranformers i altso have quite a lot of.
I dont see the point in using tubes for power aplications, when class D or even just class AB is so much more efficient and have so much less distortion in most cases.
I'l check the link though.
thanks for your replys guys!
Marius
Old 19th November 2005, 01:22 PM   #9
demogorgon's Avatar
does anyone have a pair of those 6em7 tubes, not in use?
they seem to be a good first atempt at tube audio..
cheers
-Marius
Old 19th November 2005, 06:30 PM   #10
Yep!
Someone has
Send me an e-mail, I have an extra pair of 6EM7`s to donate for a good cause
Regarding using tubes for power applications, in my experience it is because good tubeamps allways sound more natural and involving than good solid state amps.
Peter
Pair used RCA 8417 tubes battradio Swap Meet 0 3rd August 2008 10:24 PM
Pair NOS RCA 8417 tubes battradio Swap Meet 0 3rd August 2008 10:18 PM
FS: pair Hytron ST type 45 tubes jrebman Swap Meet 3 30th July 2008 01:17 PM
1 pair 6CG7 + 2 pair 6H30 tubes n_maher Swap Meet 4 11th March 2008 02:15 AM
FS: NIB Matched Pair (NEW) WE300B Tubes cartman Swap Meet 3 19th June 2006 04:25 AM
Copyright ©1999-2017 diyAudio
