| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hello,
I'm searching for at least 4 pcs of 10000 uF capacitors, voltage rating >=40V, snap-in, to fit my Mauro Penasa Ref Boards. 105°C types preferred. Can buy but prefer to trade with the components listed in this wiki http://www.diyaudio.com/wiki/index.p...e=SP_CS8414_GB Available to trade also 10uF/400V MKP caps or dual smd to DIP8 adapters with 2*OPA627 installed!! Cheers Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices |
#2 |
I bought some 12,000 uF snap ins at 63VDC from some guy in canada, who ripped me off, by putting them in a small plastic envelope and sent them international to me which banged them up quite a bit. I had to throw out some due to leaking electrolyte. I've got a few that I think are working and don't look damaged. You can have them if you want.
#3 |
Hi Andrea,
I´ve got 12 14000uF/50V caps from Kendeil which are 35.5mm diameter, 51.5mm long, 10mm Snap-in type. (1.40€/piece) Unfortunately I don´t need anything you´ve listed. Looking for GC toroids actually (~2*24VAC). But anyway let me know if they´d work for you. greets
jens |
#4 |
Jens,
Kendeil's for 1 euro and 40 cents???? Sounds like a miracle ![]() Jan |
#5 |
To be honest, Jan, I´ve never even heard of Kendeil.
Are they any good? It only says "Kendeil", "made in italy" and capacitance/voltage-value on the cap. I´ll probably skip my Aleph3 project so have a few caps to spare plus other things. (Felsic caps, toroids, heatsinks, PCB´s...) greets
jens |
#6 |
Well, as far as I know Kendeil is rated in the top segment.
1, 40 is very cheap, they sell over here for about double that price. http://www.ae-europe.nl/condensatoren.htm Link is in dutch, but I think you understand. I think it is worth while to use them and check how they sound. Jan |
#7 |
Hello,
thanks for the offers, but the size constraints are somewhat smaller, about 30mm diameter. Regards Andrea
#8 |
30mm diameter for 105° won´t be too easy to find although 85° for a "cold" amp should be fine really.
The 10000uF/40V BC Components 056 series would fit (amongst others) but isn´t 105°-type.(available at Schuro) Also going down in capacitance shouldn´t hurt really. There are 4 caps on the board anyway, aren´t there? greets
jens |
#9 |
105°C types are the preferred choice but also 85°C will fit.
In this moment I use 4700uF but wanted to use the "standard" 10000 uF value. The board uses 4 caps. Cheers Andrea
| Mounting snap-in caps | 454Casull | Power Supplies | 5 | 20th December 2010 09:05 PM |
| SNAP IN Caps 4 Sale | Coulomb | Swap Meet | 20 | 11th April 2006 03:21 AM |
| snap mount caps | d3imlay | Swap Meet | 4 | 24th September 2004 02:01 AM |
| ROE CAPS snap-in type | Piersma | Parts | 0 | 19th April 2003 11:10 AM |
| Page generated in 0.09565 seconds (80.86% PHP - 19.14% MySQL) with 10 queries |
