Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
2 Aleph Amp Case + Power Supply
Old 10th September 2005, 05:28 PM   #1
WALTER BURKHARD is offline WALTER BURKHARD  Finland
WALTER BURKHARD's Avatar
Default 2 Aleph Amp Case + Power Supply
Aleph stereo amps, Heatsinks, measured operating temp of hs is 45 degrees c. never gets hotter. Nice case. More details if interested. All i wish is to recoup the cost of parts.
Total I have made 6 cases, but I need only 4 of them.
Case Size:
420mm deep
200mm high
380mm width
The weight is near 40kg total
Front
484mm width
276mm high
Power Supply
consists of a 1200VA, 4 x 29 V, Toroid from Transtec , weight is 12kg only for the. Toroid,
20 of Roederstein 50V 68000 uF caps fixed on a PC-Board
2 rectifier bridges 50A
Soft start from Elektor
Speaker terminals from MC-Contact 100Amp-Typ , same like Burmester used in his big Power amps.
XLR from Neutrik
I would like to sell this as a set
http://pg.photos.yahoo.com/ph/burkha...r=2e52&.src=ph
My offer 730€ plus shipping from Germany for one Case only.
Cheers, Walter
Old 11th September 2005, 05:05 PM   #2
axelcs is offline axelcs  Germany
Default source for mc-terminals
Hi Walter,
where did you get the multi-contact terminals, do you have an order number? I have tried to find the number on the mc-website, but was´nt really successful. Thank´s a lot in advance for an answer.
Axel
Old 11th September 2005, 05:24 PM   #3
Default MC-Contact
Hallo, du kannst diese nicht privat kaufen.Wieviele brauchst du den von den 100A teilen??? Typ ist PR 100A.Ich kann diese besorgen diese sind gerade preiswert aber preiwerter als WBT.Da fällt mir ein Thel verkauft diese auch aber setzt Dich besser vorher hin!Meine Mail walter_burkhardt@web.de
Gruss Walter
Old 11th September 2005, 08:12 PM   #4
Magura is offline Magura  Denmark
Magura's Avatar
Default Re: MC-Contact
Originally posted by WALTER BURKHARD
Typ ist PR 100A.
Gruss Walter
Who manufactures those terminal blocks? I googled PR 100 and didn't get anything.
Cheers
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 12th September 2005, 06:10 PM   #5
Here the Link to Multi-Contact
http://www.multi-contact.com/
regards Walter
Old 12th September 2005, 08:17 PM   #6
Magura's Avatar
regards Walter
Thanks.
Magura
Old 13th September 2005, 11:37 AM   #7
Default Multicontact
Change of Company
http://www.ruhstrat.com/de/rh_klem/products.cfm/p/2.cfm
the PR-064 will be 7,50€ + Vat one Pieces
cheers Walter
2 Aleph Amp Case + Power SupplyHide this!Advertise here!
FS: COLDAMP one SPS80 power supply & two BP4078 modules in MK12 Case BongFish Swap Meet 2 18th March 2009 03:17 PM
Aleph 30 power supply jmmartins Pass Labs 2 28th September 2007 04:47 PM
chipamp case power supply karma Swap Meet 8 30th September 2005 06:07 PM
Aleph X CRC Power Supply for 60 W amp lgreen Pass Labs 3 19th December 2004 12:52 AM
Power Supply for Aleph 4 Gabster Pass Labs 27 17th March 2002 12:40 AM
Copyright ©1999-2017 diyAudio
