Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Hi-Vi Research RT2 Isodynamic planar tweeters
Closed Thread
Old 24th September 2002, 09:54 PM   #1
bbaker6212 is offline bbaker6212
Default FS: Hi-Vi Research RT2 Isodynamic planar tweeters
For Sale: one pair of Hi-Vi Research RT2 Isodynamic planar tweeters
94db efficiency
These are in mint condition and hooked up to a 2A3 tube amp (3 watts) have never been abused.
New cost was $100/ea from PartsExpress.
make offer
bbaker2002@hotmail.com
-Brad-
Old 24th September 2002, 11:45 PM   #2
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
how much for both canadian. shipped..
Jason.
Old 25th September 2002, 12:10 AM   #3
Default price
Will take US$120 for the pair plus shipping.
-Brad-
Old 25th September 2002, 12:12 AM   #4
Banned
NICE price ill have to see what i can come up with then..
Old 25th September 2002, 12:39 AM   #5
Yoda is offline Yoda
Ummm, unless thats an RT2a you have there I think the price is a bit much. The RT2a sells for $100/ea but I have seen the RT2 for as little as $32 brand new, just a forwarning to any buyers. The driver pictured is in fact an RT2 and not an RT2a.
Old 25th September 2002, 12:58 AM   #6
Banned
brad do yo have msn.
Jason
Old 25th September 2002, 01:40 AM   #7
So what does the RT2a look like and where can you buy it for $32 ???
My understanding is that all the RT2 drivers are basically the same driver with same specs, just different face plates...
RT2 18cm 28cmsq Ribbon 94db 30watts 8ohms
RT2C 18cm 28cmsq Ribbon 94db 30watts 8ohms
RT2E 17cm 28cmsq Ribbon 94db 30watts 8ohms
RT2H 17cm 28cmsq Ribbon 94db 30watts 8ohms
I'll recheck the model number on the tweeters tonight.
-Brad-
Old 25th September 2002, 02:00 AM   #8
Default More info on RT2
Here's some more info I could find.
I would like to add that I find it doubtful that the RT2 would sell for less than the $60 that parts expess sells the RT1C-A for...
RT-Series
RT series tweeters use isodynamic planar transducers that use KaptonŽ film membranes, shielded Neodymium magnet systems and aluminum faceplates. Distinguishing features are almost perfectly flat impedance with fantastic speed, resolution, and transient response.The RT1 series features a large radiating area and a cast aluminum faceplate. Although designed for use in a small 2-way system, it is also well suited for 3-way applications. Recommended second order crossover cut-off frequency - from 3kHz. *Power handling: 20 watts RMS/30 watts max *Nominal impedance: 5 ohms *DC resistance: 4.8 ohms *Frequency range: 3,000-21,000 Hz *SPL: 93 dB 1W/1m.
The RT2 series features a larger membrane and radiating area, providing higher power handling and a substantially lower cut off frequency. The large membrane is thermally attached to the cast aluminum faceplate providing cooling and dramatically increasing dynamic range. The RT2 is available with three different faceplates; circular, elliptical and horn loaded. The mild horn shape of the RT2H-A provides a 1dB increase in sensitivity while avoiding the usual artifacts of horn-loading The RT2 series are perfect for 2 or 3-way applications. Recommended second order crossover cut-off frequency - from 1.8kHz. *Power handling: 80 watts RMS/115 watts max *Nominal impedance: 8 ohms *DC resistance: 7.5 ohms *Frequency range: 1,700-21,000 Hz *SPL: 94 dB 1W/1m
RT1 RT1C RT1C_A RT2 RT2C RT2C_A RT2H_A RT2E_A
-Brad-
Old 25th September 2002, 04:00 PM   #9
well, I personally bought a pair of RT2's from speakercity.com about a year ago for $50/ea and the price went even farther down after that. they are in fact not the same, if you go to the hi-vi site (www.swanspeaker.com) you'll see that the RZT2a is rated to 1.8khz while the RT2 is only good to 3khz, a pretty big difference. The RT2 is more akin to the PE PT2 planar tweeter, its got a plastic faceplate and a smaller rear chamber than the RT2a. I do however endorse the RT2 highly, i love mine so they're still good, but they're not worth as much as RT2a's.
Old 25th September 2002, 04:20 PM   #10
OK, now I see the difference and have to agree. Well, for that price I think I'll just keep them.
-Brad-
Closed Thread
FS: Hi-Vi Research RT2 Isodynamic planar tweetersHide this!Advertise here!
FS: AR (Acoustic Research) midranges and tweeters Jack Hidley Swap Meet 9 5th September 2013 05:52 AM
isodynamic? whats that. Helmuth Multi-Way 7 17th November 2008 07:37 PM
Acoustic Research LST replacement tweeters Charles Wasserf Multi-Way 2 8th June 2008 02:28 AM
FS-16 Dayton Pt 2 Planar tweeters Badge Swap Meet 0 4th December 2007 08:26 PM
4 Bg Neo3 Planar Tweeters omarmipi Swap Meet 3 28th September 2006 02:01 AM
