Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier
Old 10th May 2005, 09:09 PM   #21
jim_vt is offline jim_vt  United States
my Decware Zen will drive a .7 ohm load...doesn't necessarily gain more power over its maximum @ 2 ohms, but it will drive happily into that low impedance load.
Old 11th May 2005, 02:24 AM   #22
Audiophilenoob is offline Audiophilenoob  United States
What are the disadvantages of using a resistor solution??????/
I'm sure there's some major ones
Old 11th May 2005, 02:49 AM   #23
would these metal films work from PE??
http://www.partsexpress.com/pe/pshow...rtnumber=005-4
4 of these in parallel??? per tweeter???
Old 11th May 2005, 03:58 AM   #24
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Default yep
Give it a try bud. Time to get your feet wet
Mark
Mark
www.kravchenko-audio.com
Old 11th May 2005, 04:15 AM   #25
LineSource is offline LineSource  United States
LineSource's Avatar
Hi Audiophilenoob,
The main disadvantage of putting a 1 ohm series resistor is the loss of 50% of the amp's power into heat. If you put 10 watts into the ribbon, you also waste 10 watts of heat in the resistor. BUT...many amplifiers sound much better, "sweeter", "warmer" driving a 2 ohm load than a 1 ohm load. My 160lb Krells will easily push 1 ohm, but sound sweeter with a ribbon driving 2 ohm loads. If your current amp will only drive 4 ohms, just increase the resistor to 3 ohms. Just avoid a step-up transformer if you want the best sound.
You can make a non-inductive 1 ohm resistor by contact cementing a sheet of household aluminum foil onto a piece of plexiglass and cutting a serpintine with your Xacto knife.
It will probably cost close to $2K to build the ribbons of your dreams. I would FOCUS on this massive and very dangerous task.
Old 11th May 2005, 07:02 PM   #26
Originally posted by LineSource
Hi Audiophilenoob,
Right now it looks like it will be around $600 in parts per ribbon.... as long as this india supplier for 5 micron aluminum comes through
well I don't care if I lose half the power... cause the QSC 850 I will use on the tweets is 430 watts at 2 ohms .... so who cares...
Old 11th May 2005, 07:52 PM   #27
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Sounds like a good way to test the tweters until you get them refined, For the final decision and implementation there are probably amps that will sound better. Perhaps when the speakers are finished, you could start on a high end DIY amp project without time pressure-you can listen to your QSC while building its replacement. Lots of newbies making amps around here.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 11th May 2005, 07:58 PM   #28
Mark Kravchenko
Default Bingo
If you still need a helping hand then you know where to call
Mark
Mark
Old 12th May 2005, 02:08 AM   #29
sound better???
how so? there doesn't seem to be any difference between the $2000 home amps that I've heard and my proamps...
A tube amplifier solution does interest me though... but from my experience all solid states as long as they're good quality sound the same...
I haven't heard a Class A amp though...
Old 12th May 2005, 04:32 PM   #30
diyAudio Editor
Variac's Avatar
I certainly am not going to get into that trap of discussing sound differences between amps but some certainly sound better to me than others. Yes, there is lots of delusion in the audio world but I would suggest trying some high quality amps on your speakers when you are done with them. Some will probably will sound better than others to you.
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifierHide this!Advertise here!
Raphaelite Audio Transformers & Sino Tube Amplifier Kits - What's your experience ? kimbal Tubes / Valves 22 14th January 2016 12:39 PM
Dx amplifier, builder's thread destroyer X Solid State 25 31st May 2009 02:53 AM
2-ohm stable amplifier PCBs or kits available? pkpickard Solid State 14 19th March 2004 03:18 AM
2 Ohms stable Transistor Amplifier... SkinnyBoy Solid State 14 1st April 2003 02:27 PM
Copyright ©1999-2017 diyAudio
