Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
WTB: 15,000uF 25v x 4
Old 29th March 2005, 11:20 AM   #1
deandob is offline deandob  Australia
Default WTB: 15,000uF 25v x 4
Needed to repair a pinball machine that has problems with poor supply regulation. 12,000uF would do also. The only source in Australia new I can find is rs-components, but very $$$.
Dean
Old 29th March 2005, 11:29 AM   #2
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Default Re: WTB: 15,000uF 25v x 4
Dean
Dean
I have some used 33000 uF / 25V philips or some new 39000 uF/25V Cornell Dubilier.
You might get away with only 2 of these, provided they fit.
If you are interested drop me a line.
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 31st March 2005, 11:13 AM   #3
Thanks Andrea.
The form factor is tight, so your larger capacity caps will probably be too physically large.
Does anyone know of any other sources for large caps?
Dean
Old 1st April 2005, 06:09 AM   #4
Andypairo's Avatar
What's the maximum size allowed?
Cheers
andrea
Old 1st April 2005, 09:43 PM   #5
Andrea,
THe caps can be up to 50mm tall by 35 diameter and pin spacing 10mm. Pretty small for the uF size - what is the dimension of your caps?
Dean
Old 2nd April 2005, 12:56 AM   #6
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
You can run wire (of a decent gauge) to some bigger caps and then use some smaller caps (preferrably poly) at the original position in parallel
Old 2nd April 2005, 01:35 AM   #7
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Andrea,
Dean
I like to use Panasonic TS-UP caps. These are 10,000uF 50v, and 35mm diameter by 30mm tall:
http://www.chipamp.com/diyaudio/snubber.jpg
I get mine from Digikey, here is the catalog page for 25v caps:
http://dkc3.digikey.com/PDF/T051/0874.pdf
The 15,000uF is 30mm D x 30mm H and costs $4.85 each if you can get someone in the US to buy them for you. The 22mm x 50mm are $4.47 each.
Brian
Old 2nd April 2005, 04:34 AM   #8
ReinoutdV is offline ReinoutdV  Netherlands
Default Roederstein's
Hi Dean,
maybe of use ??
I got here some (new) 25 V / 4700 uF of the correct size: 35 mm diameter + 50 mm heigths.
Yes....the value is lower then requested......
For 4 pieces: $ 10 , but shipping from Europe will be added.
Lots of luck finding the optimal capacitor.
Reinout
(picture added)
Old 2nd April 2005, 06:30 AM   #9
mpmarino is offline mpmarino  United States
mpmarino's Avatar
hows 'bout good ol' ebay...here
no relation to seller, but I have had good luck with him in the past...
Crazy Yankee.
Old 3rd April 2005, 12:24 PM   #10
Andypairo's Avatar
Andrea,
Dean
The Philips are 35x50 mm, the CDE 39000 uF/25 are slightly shorter, 35x46 mm.
If you want them just let me know via PM.
Cheers
Andrea
WTB: 15,000uF 25v x 4Hide this!Advertise here!
FS: 15,000uf capacitors MtBiker Swap Meet 2 17th August 2006 04:56 AM
WTB: 10,000uf Cap mrdon Swap Meet 4 13th May 2006 09:40 PM
WTB: 10x 10.000uF,min 63V jezper Swap Meet 5 20th April 2005 12:21 PM
22,000uF / 25V BHC WALTER BURKHARD Swap Meet 2 10th November 2003 01:33 PM
600.000uF SOZ PedroPO Pass Labs 47 19th September 2002 07:38 AM
Copyright ©1999-2017 diyAudio
