Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Large aluminium knobs, a source?
Old 16th February 2005, 07:31 PM   #1
homer09 is offline homer09  Canada
homer09's Avatar
Default Large aluminium knobs, a source?
Anyone know where i can source decent quality large (at least 2"/5cm diameter) aluminium knobs? I live in canada. I need two.
oh and a smaller matching one would be nice also (for source selection).
Old 16th February 2005, 07:53 PM   #2
grimberg is offline grimberg  United States
grimberg's Avatar
Have you checked Apex Jr.?
http://www.apexjr.com/knobs.htm
Old 16th February 2005, 08:06 PM   #3
homer09's Avatar
Nope, hadnt found them. But by aluminium, i guess i meant aluminium colour. Black is no go for me. Also, those are the right diameter, but way too tall, i prefer a fat short knob, if you know what i mean?
Old 16th February 2005, 08:16 PM   #4
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Large aluminium knobs, a source? Send a message via AIM to Peter Daniel
If you have access to drill press and hand drill or grinder with sanding disk attachment, you can make any shape knob by yourself: http://www.diyaudio.com/forums/showt...012#post388012
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 16th February 2005, 08:34 PM   #5
homer09's Avatar
Wow what a beautiful knob. Thats EXACTLY the kinda look i was aiming for. But since i dont have your experience or skill, i would probably not go for the bevel look, just a simple flat polished knob, a little easier and less elbow greese.
Thanks for the DIY solution Peter! Just a quick question, if i polish the knob with sand paper until i like the finish, since it will be handled frequently, will the finish deteriorate with time? What do you recommend to keep it looking polished and new?
Also, how much would a solid pipe of aluminium like that cost?
Old 16th February 2005, 08:43 PM   #6
TaskMaster is offline TaskMaster  United States
McCaster Carr caries some aluminum knobs and raw aluminuim stock... and a ton of other good stuff too!
Old 16th February 2005, 08:48 PM   #7
VT67 is offline VT67  Belgium
VT67's Avatar
Hi homer09
Take a look at these:
http://www.acoustic-dimension.com/misc/knobs.htm
Not cheap but affordable.
Cheers
Old 16th February 2005, 09:04 PM   #8
A piece for two knobs might cost you $5-8. Try MetalSupermarkets or Access Metals. They will cut it for the length you need, as otherwise it's not safe to cut small piece like that without bandsaw.
I started with 50 grid disk and ended up at 180. After that, using Scotch Brite pads ads final finish. Basically you don't really need to protect polished aluminum, as it's quite resistant to elements.
But you can spray it with thin layer of clearcoat (used for aluminum car wheels) or dip in alodine.
www.audiosector.com
Old 16th February 2005, 09:08 PM   #9
Septimus is offline Septimus  United States
Septimus's Avatar
Send a message via AIM to Septimus
Default Knobs...
They have some nice ones. My friend has the CT-3, the largest and it makes his stepped attenuator feel like butter, must with a quarter pound! plus they come in different sizes.
DIY cable.com
Old 16th February 2005, 09:39 PM   #10
thomas997 is offline thomas997  Canada
thomas997's Avatar
If you look for some round aluminum rods on ebay a lot of the sellers will cut the rod into required lengths, usually for free, or a small charge (5-10$).
Then all you need is a drill press and to sand it to your desired look.
But this is more if you are going to make a bunch of them, as the rod lengths are fairly long.
Large aluminium knobs, a source?Hide this!Advertise here!
source for knobs gary h Parts 13 25th October 2008 09:09 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
WTB 2 aluminium knobs fireman Swap Meet 2 6th August 2004 08:50 PM
Lovely looking clear-anodised aluminium knobs tcpip Parts 5 4th March 2004 10:49 AM
source of aluminium in UK Matttcattt Parts 9 7th May 2003 09:19 AM
