| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hi, im looking to buy above mentioned transistors, matched!
Anyone have some of these or know where one can find them matched? |
#2 |
I bought two pairs from Elektor magazine customer support back in 2001. Mind you, they set me back about 60Euros.
#3 |
Don't waste your money on them.
There is more fake than anything else on the market. I've bougt 2 GT20D201's and 2 GT20D101's at different places and they both were fake. As thi was for a school project some of my fellow students bougt these IGBT's too...guess what: worth nothing! If you whish to buy them...I wish you all the luck (BTW, isn't it strange that you cannot find any other IGBT for this purpose and these IGBT's aren't manufactured anymore?) |
#4 |
The GT20D101, 201 devices are just not available.
I have not been able to find a better transistor to replace the IRF540/IRF9540, 150W transistors in the Giesberts HEXFET amplifier design. These are cheap and easy to find at newark.com . IMO, the best way to boost the power output is to use two paralleled IRF240, and two IRF9240 transistors which are pretty good complements to each other and can handle 125W each. So, using two per side can handle 250W which is more than one GT20D101,2 transistors can do anyway (180W). They are also good up to 200V so you can increase the power supply rails up to +/-43V (or higher) as specified in the IGBT upgrade article in elektor magazine so that you can deliver more power to the load. This modification is rather more complicated, however, as the compensation will most likely need to be changed and each transistor will need separate 0.1 Ohm source resistors and gate resistors to ensure good current sharing and prevent oscillation. This could be done but a lot of work. I think it would be eaiser to just build up two mono block bridge amps using four of the original HEXFET amps. This would give you 240W per channel into 8 Ohms. brj |
#5 |
I have about 35 of each device available. Both are group "Y". Who wants them all?
Edit: Yes, they're real Toshiba's. Last edited by Andrew Eckhardt; 1st November 2009 at 07:29 PM. Reason: more info |
#6 | |
Hence, I do need a pair. How much do I pay and by what mode? And by the way, how much do you want for the whole lot? Is there any schematic where they do shine? Thanks,
Sam |
#7 | |
| Where to find GT20D201 and GT20D101 | goldyrathore | Solid State | 9 | 9th March 2012 10:50 AM |
| IGBT amplifiers | Bama Slamma | Solid State | 46 | 29th September 2010 11:24 AM |
| IGBT Still Alive | Stee | Solid State | 7 | 2nd October 2008 09:48 PM |
| H-bridge IGBT | speakerguy79 | Solid State | 0 | 20th October 2006 11:42 PM |
| IGBT's for sale... | jazzpeter65 | Parts | 0 | 9th February 2004 06:57 PM |
