FS: R-core transformers, audio caps, diodes, DVD player, etc - diyAudio
Go Back   Home > Forums > Commercial Sector > Swap Meet
Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Old 31st August 2004, 01:11 AM   #1
Default FS: R-core transformers, audio caps, diodes, DVD player, etc
I have a bunch of stuff sitting around the I'm sure could do someone some good. Here it all is:
Qty 24, BYV52-200 (30 A 200V) Ultra-Fast recovery doides. Do a search on Mouser, they're 2.41 each. $1.50 each (minimum 4), or $30 for the whole bunch.
Qty 1, R-core transformer with dual independant 12V secondaries, 50VA each secondary, 120V primary. $25.
Qty 1, R-core transformer with dual independant 30V secondaries, 50VA each secondary, 120V primary. $25.
Qty 2, Renco split-bobbin 20VCT, 24VA PCB mount transformers (independant secondaries at 10V.) $6 each.
Qty 4, 10,000uF 50WV Nichicon CEW capacitors with solder tabs. $15 for all four.
Qty 12, 10,000uF 16V TSHA Panasonic capacitors, snap-in. $24 for all 12, or $2.50 each (min 4.)
I also have a Sherwood Newcastle V-756 DVD player with built-in 6.1 channel decoders, titanium finish, orignially retailed for $800, available for $140 (price reduced.)
Make an offer, especially if you are looking at more than one item. Thanks!
Paul
Old 2nd September 2004, 06:09 AM   #2
thomas997's Avatar
How good is the decoder on the DVD player?
Would it need a preamp after it if I wanted to use it with a chip amp?
Old 3rd September 2004, 01:04 AM   #3
The decoder for 2-channel is (I believe) the PCM-1704, a Burr-Brown 24-bit DAC. It doesn't say in the owner's manual, but if you are interested I'll pull the case off and check the PCB. The unit has a digital input, so it can do the decoding work for a CD changer or other digital source.
For audio it has 2-channel and Circle Surround. For Video it has DTS, DTS-ES, Dolby Digital, and Dolby Digital EX. It also says it will do MPEG Multichannel, but I've never heard of that so maybe it was "up and coming" 4 years ago and never caught on.
Let me know if you have any other questions.
Paul
Old 3rd September 2004, 03:22 AM   #4
thomas997's Avatar
thanks
no need to open it up though
Old 4th September 2004, 05:21 PM   #5
enochRoot's Avatar
hey paul_
i had sent you a pm, but didn't hear back. if you're busy...sorry. but just in case you don't check that email account...i thought i'd post it here. i'm interested in the 12v r-core transformer.
thanks!!
Old 8th September 2004, 03:22 AM   #6
Default update
An update on what is left, a price reduction, and a correction on the secondary voltage of one of the R-core transformers.
Qty 16, BYV52-200 (30 A 200V) Ultra-Fast recovery doides. Do a search on Mouser, they're 2.41 each. $1.50 each (minimum 4), or $20 for the whole bunch.
Qty 1, R-core transformer with dual independant 10V secondaries, 50VA each secondary, 120V primary. $25.
I also have a Sherwood Newcastle V-756 DVD player with built-in 6.1 channel decoders, titanium finish, orignially retailed for $800, available for $130 (price reduced again.)
C-core transformers edrel sison Tubes / Valves 25 1st October 2015 08:10 AM
R-CORE transformers in Europe tvicol Parts 18 25th July 2014 10:58 AM
R Core Transformers jimmyd53 Parts 50 9th December 2012 07:00 PM
Where to buy R-Core transformers? chris719 Digital Source 6 7th December 2012 05:56 AM
Has anyone tried any Double C-core transformers? (4a SS amp kit) gonefishin Solid State 15 24th May 2004 08:39 AM
Copyright 1999-2017 diyAudio
