Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
Good quality small size potmeters?
Old 7th May 2004, 07:53 PM   #1
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Question Good quality small size potmeters?
I need to replace the volume pot in a AMC CVT1030a, since turning it makes the cones almost run away from their basket before coming back in place ... the problem is its size: it is very small, with overall diameter 16 mm and pin spacing about 6 mm.
It is stereo, 20kAx2 is the writing I found on it.
Can anybody suggest a suitable replacement (or even better have one to sell or trade for some good components)?
Cheers
Andrea
Old 8th May 2004, 06:55 PM   #2
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Is it the same as these?.
If so, I have some used, but good condition ones, I think 20K linear. If the're any use I'll stick a couple in the post.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 9th May 2004, 08:15 AM   #3
Andypairo's Avatar
To be true they look more like these... one thing I forgot is that there is, coaxial to the main shaft, a metal ring that operates only one of the two cursors to achieve balance between channels (but this method IMHO did not work properly...)
Anyway thank you.
Cheers
Andrea
Old 9th May 2004, 05:39 PM   #4
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
Hi, how about these ones, not available in the 20k value, but I think they are a close fit for the size (I'll measure one of the ones I have knocking about if you want me too to check) if you can cope with the different values.
Old 10th May 2004, 07:47 AM   #5
Andypairo's Avatar
They certainly look alike, apart from the missing balance gear.
However don't know if the value can be changed so easily, should check the schematic...btw do you consider them as good-quality (suitable for a volume pot)?
Cheers
Andrea
Old 10th May 2004, 09:54 AM   #6
bigparsnip's Avatar
Hi, I'm not too sure about how they sound, as the only one I have ever used is as a volume control in my first gainclone amp (which should be finished in a day or two now), but they feel reasonably nice in use, quite a nice smooth, light action when turning. But, then I guess at 80p each it wouldn't hurt your wallet too much if they wern't so great.
Anyway, I gave mine a quick measure just now, and it is about 17mm accross the case at the widest point, and the pins are around 5mm appart (6mm if you measure from one side of the frst pin, to the opposite side of the second). Also, if you wan't me to get one each of the two values to have a try with, just let me know and I shjould be able to get them too you pretty quickly.
Old 10th May 2004, 10:42 AM   #7
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
You can probably just use a 2-gang pot and ditch the balance part. The most common type of balance circuit simply makes a variable potential divider that is totally out of circuit if you remove the pot.
If the pot was log then you may be able to use a different value. However, with it being lin then it may be that the value is quite critical to achieve correct law-faking.
Old 13th May 2004, 10:37 AM   #8
Andypairo's Avatar
Maybe I'm lucky... on Italian Ebay I found some Noble pots of the right size and value (or at least it seems so...).. even with loudness tap...
http://cgi.ebay.it/ws/eBayISAPI.dll?...sPageName=WDVW
Cheers
Andrea
Old 13th May 2004, 10:30 PM   #9
joensd is offline joensd  Germany
Alps produced exactly the same pots as you´ve shown.
You could(can?) find them in any commercial amplifier (Sony,Pioneer etc..)
Not sure if they still manufacture them.
Have a look at the RK16 series from Alps. Should fit.
Jens
Good quality small size potmeters?Hide this!Advertise here!
WTB: descent quality subwoofer(s) any size Jimmy154 Swap Meet 3 25th June 2005 07:17 PM
best tweeters in small size maxxx Multi-Way 1 7th March 2004 05:53 AM
