Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers
Closed Thread
Old 14th July 2002, 12:57 PM   #41
kristijan-k is offline kristijan-k  Croatia
Hello,
The standard light bulb can not be used for the exposure.
But, if you can't find the UV lamp, it is possible to use the 500 - 1000 W halogen lamp (reflector).
Try at distance of 30 cm, 45 sec. (500 W)
Note that you must use the glass over the film, and that some heat will be dissipated from the halogen lamp.
Kristijan Kljucaric
Old 25th July 2002, 08:10 PM   #42
chorei is offline chorei
i think that somewhere on the market i saw the infrared lamp.
does anyone know is it possible to use IR lamp?
what is the difference between UV and IR lamp when doing PCB exposure ?
Old 26th July 2002, 04:39 AM   #43
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
IR and UV are at opposite ends of the light spectrum and are certainly not interchangable.
Old 26th July 2002, 06:42 AM   #44
mpopovics is offline mpopovics  Hungary
mpopovics's Avatar
The photo lack is sensitive for UV light, usually (I mean the Positiv 20 spray).
The high power halogen lamp can be ok also, I agree with Kristjan.
BR,
Milan
Old 26th July 2002, 04:51 PM   #45
thanks AudioFreak and mpopovics,
i brought the 500 w halogen lamp and i will try to do it like kristijan-k recommended.
how much there must be NaOH in the water ?
what about water temperature ?
Old 27th July 2002, 09:41 AM   #46
hi,
the precise amount of NaOH in the water depends on photoresist manufacturer and of photoresist age ?
..and what period of time the pcb must be in the NaOH solution ?
Old 27th July 2002, 10:30 PM   #47
Hello,
Yes, the precise amount of NaOH in the water depends on photoresist manufacturer and of photoresist age.
The period of developing is also depends on precise amount of NaOH in the water, photoresist manufacturer, photoresist age and how well is done the exposure of photoresist.
So, you must done some visual checking when developing your artwork.
Use room temperature solution of NaOH and water.
Kristijan Kljucaric
http://web.vip.hr/pcb-design.vip
Old 28th July 2002, 05:56 AM   #48
trigon is offline trigon
trigon's Avatar
Hi Kristijan.
Any experience with Gold plated PCB, is this applicable to your boards as addition and what is your opinion about this. I personally think that it should improve things.
Thank you in advance.
Trigon.
Old 28th July 2002, 01:37 PM   #49
Hello trigon,
The gold plating of the PCBs is possible, but it is just unneccesary to make them that way, and the cost is not justified.
There is no way to get any better sound results with the gold.
The main purpose of plating the PCBs is to protect the Cu tracks and pasds against corosion - oxidation, for improved solder joints when soldering thus lowering joint resistance.
Also, there is much less risk for cold joints.
On my PCBs I use Pb-Zn track overlay.
I enclosed the picture, and like you can see, the silver look of the pads are achived by tinplating.
The all tracks are tinplated, even under blue soldermask.
Best regards,
Kristijan Kljucaric
Old 28th July 2002, 05:41 PM   #50
trigon's Avatar
Thanks.
Closed Thread
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiersHide this!Advertise here!
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 27 11th November 2017 02:13 PM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 03:15 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 12:11 PM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 07:29 PM
Trade Aleph X PCBs for Aleph P 1.7 PCBs highbias Pass Labs 0 27th September 2004 06:59 PM
