Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
TDA 1541A S1 silvercrown @ ebay
Old 18th April 2004, 09:04 PM   #31
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Smile Thanks Peter
I will study this carefully.
But take a look at the pictures, it is written TDA1541/S/N2.
The datasheet names S1 as TDA1541 N2 S1, and so does my billing from the S1 I bought if I recall that right.
Old 18th April 2004, 09:33 PM   #32
guido is offline guido  Netherlands
guido's Avatar
Originally posted by Bricolo
The Left and Right channels are separated, so it's not vanilla IIS but maybe some sony format.
What I don't understand is how they get one chip to output L+ L- (or R+ R-) , especially with the DAC configured for IIS input
You'll also notice that even here, BCK is connected to SCK. And even more: pin 4 is reffered as SCK, on this player designed for a TDA1541A
Maybe some pre-processing is done in the digital filter, to send some tata when WS=0, and the 2's complement of the same data when WS=1
The FF only seem to be some synchronous reclocking or WS and Data, synchronously to BCK.
Guys please: pin 27 is connected to 28. It IS I2S for the TDA. That it gets +left and -left, it is unaware of. It just converts whatever comes in. Sounds very familiar to me
The dig filter must be configured to split i2s and feed +l/-l and +r/-r to the dacs. There is no other way this would work.
Pin 4 is strange. SCK does not exist on A version, so it is no use to put crap onto that pin.
More interesting that this, is that the -5 is made from the -15 and not from a separate supply. It makes sense, if you read the post in the digital section.
gr
GuidoB
Old 18th April 2004, 09:34 PM   #33
guido's Avatar
Originally posted by Peter Daniel
I still don't know how to split data into right and left channels.
Why not, the info is available in the digital section..
GuidoB
Old 18th April 2004, 09:37 PM   #34
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
TDA 1541A S1 silvercrown @ ebay Send a message via AIM to Peter Daniel
I wasn't following that topic lately, that's why I guess
Which thread exactly? Not the one you started a year ago, or so?
Old 18th April 2004, 09:48 PM   #35
guido's Avatar
It is longer than that and i did not start it. Called 2 TDA1541A in the digital section. Splitting works well.
However, thanks to HtP in the tda1541 info post, i now know that things can be done better around the 1541 (dem reclock, PS, I2S signals etc). So i'm gonna check that out with a new dac with only one 1541 first.
As for this old post: the GAL definitions can be done simpler (mentioned in other posts, seatch for 'GAL' and there is one improvement on the schematics (not tested yet):
pin 1 from the GAL (clock) should be connected to the 11MHz with an inverter to remove the jitter introduced by the '161 on BCK.
GuidoB
Old 18th April 2004, 10:21 PM   #36
Bernhard's Avatar
@ the moment I would be more interested in splitting the signal into +r/+r and -r/-r.
2 chips for each channel.
My listening impressions so far:
SAA7220A + TDA1541A:
Strong odd order harmonics and suppressed even orders
Sounds
SAA7220A +TDA1541:
All harmonics distributed evenly, low distortion
Sounds detailed and clean.
SAA7220B + TDA1541(A):
Very good values for K2/K3, but dominating K5
Sounds clinical, narrow and dry.
TDA1541(A) non os:
Medium distortions, but mostly evenly distributed, suppressed K9 & tendential stronger low orders.
Sounds very open & relaxed due to rich harmonics, a little bit watered though.
Old 28th April 2004, 09:54 AM   #37
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by jean-paul
Exactly, this is not standard I2S. CD 7 does not use a standard digital filter but a specially programmed DSP.
Jean-Paul, do you know if the 1541s in the CD7 are used as non-os, 4*os or 8*os?
Old 28th April 2004, 08:45 PM   #38
guido's Avatar
Not JP, but i can answer this too:
It says: i2s format, 16 bit word, 4fs data
So 4 times oversampling.
It also says
D/A conversion 1-bit linear/channel
mvg,
GuidoB
Old 2nd May 2004, 07:08 PM   #39
Bernhard's Avatar
Another S1 here:
http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=3093983492
TDA 1541A S1 silvercrown @ ebayHide this!Advertise here!
D1 I/V with TDA 1541A smario Pass Labs 22 23rd August 2006 03:24 PM
Tda 1541a S1 / S2 Peter K Swap Meet 2 20th May 2004 08:09 PM
Are 1541A S2's still available? ericsphillips Digital Source 1 24th February 2004 07:41 PM
TDA 1541a n2?? setmenu Digital Source 0 16th December 2003 03:24 PM
TDA 1541a S1 Praudio Swap Meet 2 5th October 2003 05:23 AM
Copyright ©1999-2017 diyAudio
