Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
TDA 1541A S1 silvercrown @ ebay
Old 18th April 2004, 09:21 PM   #21
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
TDA 1541A S1 silvercrown @ ebay Send a message via AIM to Peter Daniel
One channel output stage
Old 18th April 2004, 09:23 PM   #22
Close up of one module
Old 18th April 2004, 09:26 PM   #23
grataku is offline grataku  United States
thanks for the explanation,
Peter, that looks like an exceedingly complex I/V stage, you do own a cd7, right? How does it sound?
Old 18th April 2004, 09:31 PM   #24
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Default I'm not Peter but...
Its just an opamp I/V, opamp LPF and opamp output stage. It looks complex because it is built discrete ( HDAM ) and balanced. Compare it to a cdplayer with normal opamps and you'll notice it is almost the same except for the balanced design which doubles everything. In a Denon with balanced outputs there are 3 dual opamps per channel doing the same job ( with more circuitry internally but with much smaller footprint ).
I expected a nicer I/V to be honest.
It's only audio. Member of the non modular PCB design committee
Old 18th April 2004, 09:39 PM   #25
No, I don't own this unit, just the service manual.
But I would be definitely interested in building balanced DAC, similar to that, but with much simpler output stage.
I still don't know how to split data into right and left channels.
Old 18th April 2004, 09:47 PM   #26
Bricolo is offline Bricolo  France
Bricolo's Avatar
The Left and Right channels are separated, so it's not vanilla IIS but maybe some sony format.
What I don't understand is how they get one chip to output L+ L- (or R+ R-) , especially with the DAC configured for IIS input
You'll also notice that even here, BCK is connected to SCK. And even more: pin 4 is reffered as SCK, on this player designed for a TDA1541A
Maybe some pre-processing is done in the digital filter, to send some tata when WS=0, and the 2's complement of the same data when WS=1
The FF only seem to be some synchronous reclocking or WS and Data, synchronously to BCK.
Old 18th April 2004, 09:49 PM   #27
jean-paul's Avatar
Exactly, this is not standard I2S. CD 7 does not use a standard digital filter but a specially programmed DSP.
Old 18th April 2004, 09:56 PM   #28
The DSP
Old 18th April 2004, 10:00 PM   #29
The format out
Old 18th April 2004, 10:00 PM   #30
Bricolo's Avatar
Ok your message confirms that I was thinking.
Instead of a classical IIS signal like this:
<WS=0> left data bits <WS=1> right data bits [DAC outputs analog values] <WS=0> next left input....
we have this:
-left DAC:
<WS=0> left+ data bits <WS=1> left- data bits [DAC outputs analog values] <WS=0> next left+ input....
right DAC:
<WS=0> right+ data bits <WS=1> right- data bits [DAC outputs analog values] <WS=0> next right+ input....
You need a DSP to do this
TDA 1541A S1 silvercrown @ ebayHide this!Advertise here!
D1 I/V with TDA 1541A smario Pass Labs 22 23rd August 2006 04:24 PM
Tda 1541a S1 / S2 Peter K Swap Meet 2 20th May 2004 09:09 PM
Are 1541A S2's still available? ericsphillips Digital Source 1 24th February 2004 08:41 PM
TDA 1541a n2?? setmenu Digital Source 0 16th December 2003 04:24 PM
TDA 1541a S1 Praudio Swap Meet 2 5th October 2003 06:23 AM
