Caps/Resistors/Trafos/Mercury Relays and more
Posted this back in 2014 and re-upping to get rid.
Time has come to admit to myself I'm never going to have time to make stuff out of all the parts I accumulated some many years ago inspired by these forums. Collected it all together as a big project while living in a nicely done flat, moved to a biggish house which is a massive project in itself and haven't stopped DIYing that since.
This post will be edited as I get around to listing the stuff out, there's all sorts from Vishays etc, caps, mercury wetted relays (loads of intended for a ladder attenuator), teflon PCB material, transformers, mains filters, all sorts of stuff I've forgotten about too.
All prices are my first stab as I am out of touch so if you think I am out of whack make me an offer.
Panasonic HFQ 1500u 35V low ESR radial electrolytics - I have c900 of these, bought for massively parallel power supply arrays, 8 unopened bags of 100, one open bag of approx 100 (will count and pro-rata sale price on sale). £20 a bag plus shipping which is a steal for caps of this quality.
Spec here including chart showing very long life span
https://industrial.panasonic.com/cdbs/www-data/pdf/RDF0000/ABA0000C1100.pdf
2 x Aerovox Aero M metalised polypropylene capacitors, 1900u, 300VDC, £5 the pair plus shipping
NOS Caddock MP816 1R 1% Kool Pak Power Resistors. TO-220 package, 2.25W without heatsink, 16W with. Top notch metal films. -20 to +80 ppm / C temp coefficient. £1.50 each, discount for bulk. Some sold but I have lots left (300+). These are NOS super high quality resistors - £7 each in 100 quality from RS.
Datasheet here http://www.datasheetarchive.com/MP816-datasheet.html. Past sales thread back when: 1R 1% Caddock MP816 power resistors.
38 x NOS Wima MKP4 1u 160V metalised polypropylene capacitors - 75p each plus shipping, discount for the lot
8 x NOS Wima MKP4 0.15u 400V metalised polypropylene capacitors, 50p each plus shipping, discount for the lot
3 x Corcom 20ESK6 mains filters, 20A, 120/250V, 50/60 Hz. £10 each plus postage
24 x 120A 80-100V IR 123NQ100 dual Schottky rectifiers £7.50 each plus postage (available on ebay for £40-£60 each)
http://datasheet.octopart.com/123NQ100-International-Rectifier-datasheet-41320.pdf
12 x UES2602 rectifiers, £1.25 each, £10 the lot plus postage
[/QUOTE]
TO3 thermal pads - 2 x bags of what looks like 100 (will confirm on expression of interest), each bag £5. TO-220s are sold sorry
Surface temp sensors for thermal protection - 55 degree x 9. £5 the lot.
Mercury wetted relays - 75 of them Clare HGJ2MT-54211-G00 5V (typ) 14V (max) contacts, shielded, DPDT (2 Form C). These things are just so nice, a bit like the caddocks I don't want to part with them even though reality is I am never going to put them to use (they were destined for a logic controlled relay-switched volume control). I don't know what to ask for these - they are so hard to come by let alone in this quantity NOS. Still available new at £168 each! £10.00 each plus P&P and make me an offer on the lot.
s
Specs here: http://skory.z-net.hu/alkatresz/HG_higany_reed_relek.pdf[/QUOTE]
And yet more, octal base ones these, great for switching on those steam-punk valve amps. £17.50 each.
240V 3.5kva powerstat variable autotransformer/variac £50 plus postage at cost
75 x P2N2222A new in packaging - £2.50
10 x NOS Magnecraft power relays - perfect for on/off power switching taking that massive inrush - see pic for specs. £7.50 each, discount for the lot.
34 x STPS80H100C Max 247 package Schottkey rectifier - £2.50 each plus p&p
Tektronix P3010 300V 100MHz 10X CATII passive oscilloscope probe - NOS in sealed bag - £50 plus p&p
Vishay-Dale VSR bulk metal foil resistors, 2k21, 0.5% tolerance. £2.50 each plus shipping.
https://jbjimg.am.files.1drv.com/y4...8Whsl6FqA?width=576&height=1024&cropmode=none
300 x IRF630 TO-220 mosfets (SEC - ie Samsung) in antistatic sticks of 50 - £10 per stick + p&p
296 x IRF9630 TO-220 mosfets (SEC) in antistatic sticks of 50. £10 per stick +p&p. (A retainer pin slipped on 1 stick and 4 transistors came out in packaging sent to me, leads got bent and who knows if they survived - will be included to keep the others snug but clearly marked, 50p off that stick)
Vishay-Dale RNR/RLR/RN55/RN60 - see reply #3 below for pics. Sold.
6 x Nuovetem Talema mains transformers, 2 x 115 V primaries, secondary 1 24-0-24 504VA, sec 2 14V/1.8A sec 3 12v 0.83A, unused NOS -SOLD
24 gold plated rca chassis sockets - SOLD
32 x Panasonic TSU radial electrolytics 1000u 100V - SOLD
2 x Cornell Dubilier 11000u, 80vdc electrolytic radials - SOLD
2 x Rogers Duroid 5750 doubled sided teflon substrate pcb board material, each 30cm x 45cm - NOS in sealed packets. SOLD
1 x Rogers Duroid 5870 doubled sided teflon pcb board material 30cm x 45cm - NOS, still has protective plastic film on both sides. SOLD
50 x NOS IRF610 in sealed RS anti-static packaging - SOLD
9 x Vishay-Dale power resistors, 75ohm, 50W, 3%. SOLD
More Vishay-Dale, not quite as swish as the VSRs, but nice metal films - mix of types and 1/8W and 1/4W. Mostly bagged up by value, were sorted out from a job-lot. I haven't counted them all, but by weighing 10 bags and multiplying up I think there are circa 700 in total in the bags, and maybe 100 more loose.
Bagged ones are mostly RNR (marked FSCJ on the bags but that's a code not the type) and RLR (milspec version of ERC). Light blue are also RLR (RLR20C) and brown ones are RN55E / RN60D.
The RNR and RLR seem to go for 50p each so, let's say 700 (ignoring the loose ones to undershoot on the low side) x 50p = £350 then halve it for £175 and then knock a bit more off for £150 the lot plus P&P at cost.
Specs:
https://datasheet.octopart.com/RNC50J1001BS-Vishay-datasheet-13261008.pdf
y4mxdnj8sLUHc3NrdImjrBEgT3UpuRd0UUnK4o07FWkVjSSz5iKNtFufNf5aRCLdd2nPip0dDvSsxyikUzsHEjWNOMlmZQoaWlBRh5RGvV7uDWyrhuExzKkz95d9zjETNUVdbuU1X9SowRtDZHgmcDeZZdt6X_ALSrw49pjOZAhnmoYAAtecSC5KLI3esXOCbUCxuv7MaAWyX6CfoDmy0JERg
y4mEU5wwVgg5hOge5np8M156TOmUS1Y6va7emTYIcMBR4m-Ww8Zfn9QZyO5VzgNWtQgD_qVjuUt81VunVcvyMvArhjuYXd8UwwdaS5UdL93negtA65u5-8ZVDNzcuAZDYhkIm6wxt0v7t3eO-kaJO7wsh7UaoAta0lFL_1n8fXdhBU6RGd8q9Pmz96qK0uCpRN2vAuYn2FdDxztX_aYN6vVeQ
y4mbza2htsAcPYXcNA9k4W70hNIg156-Lj_VMOyD8uxGuI2ylnCCBr0hdY5-ZF6cTgWRqsa52u6sqkupJzpq_JO4GIDno_Fh9hEQuoADmJlYACoN-vL68rd6ek5SQKpqZQSK_AZeqprgYyGLzKjG4u1MbsoECuuHuLUeM656HQWk1VZiftTwVmtRxCp5QEIJ7xgrUTpXGhZyDrMNFag4YT8RQ
y4mQEe8-KgCH7b6Dcz6NtelEJ-8nWOzr5MinU4ItNMp6lNevpw4Lrhwjiy1wlycdyj0Pg5bEyWsK_NGDasLdw0w4om2ia95zJDnIK8CIp3__GxNr3--So7ZmywmCrGqmvqqyR65hS1v_GF2Xu4EIDV24RNWxT_dnmoCe2UMj88-u9uz8wMIBgmFLxsupb6iVMtwqVcAb_gKN8rfXWE3uYxCSw
y4mtDzi-bztvaX_3b0Hg8mInlW3U26fc2qvUiAhXfqaT-xsGZlcK_hf97axzTvK3UEGYW7Wb42DDplQdEpN1LQ8TLZtVS9gzKqaJeo4Ml3u5u3tlzTbgw9CkzfUV_k5Ig1kAfcTHC_cUwSKLh8yy5a9KGZs6LyO9Uojfa12yM5DsoYqjC4quo_VT-1dFXLQM266dTilNK6jVRGWGQnqWoGOmw
y4mAFcgBHB1iqV_raJ_J4PR1tuPvN_wgPGBssaLaOwrUOJE58mCUsKeFyPLiSU1K-6xXRMI5fQTuIywvpUSOaYiuiHKZ83YahOZBN9TtPo7GMyUPFmKxRtLbJOAhiyMeXZ0No0CkvOl2f1jnlpZ51p-L4rCP5Bth2SWtwoswdco0X-7SnuXRCanCmRd8WjMTmryQTciklAoaRxDSy8FuEX4Vw
y4mlampE4uh6yiLs1BP4GPYn1-_s1sgNOvoACWw9VHthYWinQ7QYoV8IVrEQV7nd5I1ZXHPhTSXKDj1lMMWRFTqHciN0sQU5yGbXrEUzw_VTFRM04kfDPD9hf3w1YvkpVumlo9AtOsQIYIHWAlzRjYeSt4upvq1AxepF0stWY4lBFiCVZ9TxF9H1RIpQjxAaMhUW7wwOrgIu2zbEJLGv8TfXQ
y4mIBg4dp2NI9LowXoeQ7shRFYEMm8du7K5XsLJYQ48FFtjxsGzXhWoaxrtEeLIPUTJtZ6EO0HzUI_l5d-qrZkagmIaifrxibh0gKKqtFe7Ij9yq6WyVB-P5ilG4lcxDfkpHm9uYNuZUSJMEO07eDWc9QY5Y6G1juo_U1seVo8MtDZ-53Bu9uI1BVL21RsDDk_h5Id0o-zXF1Xr0oMUXbjUFQ
y4mn5tqOfxfcJXsofWdzCv6mnGz21zWeexu3d_sU8QUIh-mnvxP-MiMX8K3WZjP64nelVJuQyXjzAoQu2yXq5FWkRW6OJCx0kdFCOBzpAUySSNgsjXmsK98fD8rdQXtiblBg0FU6xAMdAByqOlo9ZiMSTy1JtCB78UDfZQNI2nVts5DHw-sfI8fC6CHhM9inrV65VbXXdC6GTucFvw-Mhj1yw
y4m1-4Us24iiRM8pfFCDoGUVHilmhgZxRs5uy5cgt72g9skKlCgnpHretpuVFAKAWrNbu3PgZ9G32fdCSpnO3nOnoDi1u17Xx-X5T_OWTt54iKoXACO5cmcVVA0KYitRWRBOLHn-re5ZoVpENUZ7Ca3-5RdibOB9T2kWley2gpaVvelbIFbW9dA1bfaXPgPlteqZVmqhjkM5PkecBLLDsHk1g
y4mVvF26rmhiCzEtoPfkesyW4BvpKESjYUvKIyzza2xOCMi8jO32OlgmjatxixxsvZXEpgjki8eSD2UjJERb0vZtODFBNbc9DI993bDYr7rZxn_Hhso-9qk2PRn97tPIyQMVop8DA0eJN-bUV0BMmxrcIqe5vo9qcLg-su46oaJyyl4sAytoiozpD6oUXwLOwjQ4LkvtxMM_XKjkP5khvsGDg
y4mowVKpcCKX0iAfJoUPSm8ym_d827kjiavMlZa2kyg-SQeAsCH_RscdJoXm_joALj0qARtmnkbVzCIM7kYO31FpkxYhdpRTeC39EcXaHP3DPK7W-C1XJPumxj-5YRj4_cso0R5h7LlgOH-aifD9sU5Kr9TD1J5Br55JCezDpEfMIGm7pCMHvulEczoXINGbm-77dwCNfaNIPvoBFp4VydWmA
y4mm_4rYvBMLewpg3eJHzDKB6v9jpP7BSLnWE7TNMbAib69JxA2ysvhUWR253wdp5yVuffnKKcANVJslhs-utYtz-p9JkIK9PUdCHDLB0k_T4jsvptpqN_Q8waxECy0UR82HwUy8bVjDGA6sA9oCxdUX_L6OPTk4FKYOGTKUoVEp1XYWAYzt80_Y8rsAOdQSgL-xI-_SMPsyQC6pjd16YAxZw
y4mRejWmfE_hdhOaiU_DutJMfOXqoTh0DdnRD-t4a3siBwlzK34pg_XjR67JEXad2oukmT0ZGa6vqutli2I_1LYLmVeF0x0qTLWqKept-6HFs-4VKmbD9bmQBWFyQ8briN41rBF-YtebJ0GHeDKsg2my3LP4u0FJHZKS48nvdf8IADCKmg1aw_XjbCOy72cMzi9eYZsXIvM7ZPzLCJEJKSDlw
y4musyk1JW1OcJjLKA_N8d-yt-s9J3UogZ0fCJgQJysxi7x9Vm_7yxfWjMaANkDLV4pwKhIhYKuRyhvp1Z3u37D3q-3fcRsJPCd6otnWsmpxC1DWZ10GRUbOeE7I4wOmplNcdKT-8AdN1_oNDrYNLnWL25TWkNVczymFUjDLddsUkgQdYo8EblmjTdZsiTayu5J_Vh7li50bhXbLxggZOFIVA
