FS: LM3886 PCBs
For sale: Compact, low distortion, easy to build LM3886 PCBs
For sale are compact, low distortion, easy to build PCBs for an LM3886 amplifier.
  • Compact: only 2.9x1.2in (one channel), with the same mounting pattern and a similar layout to the boards previously sold by ChipAmp.com (which, sadly, seems to be out of business, and to which I am not related).
  • Low distortion: advanced signal routing offers superior performance. THD+N is less than 0.002% when driving 18Vrms into 8ohm with an unregulated power supply. The distortion spectrum is "soft", with a low level of higher order harmonics. The high frequency linearity is also excellent.
  • Easy to build: The schematic is very simple, with only a few parts and nothing exotic. A more detailed description, including the schematic and BOM, can be found in the posts #2 and #3 below.
The boards come in two versions (see the attached photos), through hole and SMT. Both versions have similar performance. SMT verso comes with SMT parts pre-soldered.
  • The through hole version is a simple non-inverting LM3886 amplifier.
  • The SMT version uses 0805 parts and can be used as inverting, non-inverting, or balanced differential input amplifier.
The discussion and measurements can be found at the Chip Amps forum.
Should you be interested in the SMT version, please send me a PM.
The through hole version (as well as the PCBs for a bunch of my other projects) is available at HiFiOcean.com for only US$9 per pair (one board is for one channel; a pair makes a stereo amplifier) plus shipping. I am also offering it on eBay.
Schematic and BOM - through hole version
Attached are the schematic, PCB artwork and the BOM for the through hole version.
  • MyGC TH BOM.pdf
    MyGC TH BOM.pdf
Schematic and BOM - SMT version
Attached are the schematic, PCB artwork and the BOM for the SMT version. Note that the inverting input must be grounded or driven by a low impedance source (e.g. a local opamp is ok but a long cable is not) to prevent instability.
  • MyGC SMT BOM.pdf
    MyGC SMT BOM.pdf
A note on power supply
The PCBs are designed to work from two isolated power supplies (e.g. 35V + 35V) connected by four wires (V+, PG+ for the positive rail, V-, PG- for the negative). They will work with a bipolar supply with a common connection shared by both rails (e.g. three wires V+, V-, COM), but the distortion will be higher.
For my tests, I used a 100VA 2x24V toroidal transformer and a ChipAmp.com PSU board, consisting of two 4x MUR820 bridge rectifiers and two 22,000uF filter capacitors.
