FS: Holton Modules / ICE-Power
For sale Holton and IcePower High-End equipment:
1) Holton Precision Audio equipment:
2 x HPA-NXV200L R4 amplifier modules.
2 x VoltOne
1 X HPA Power One R3.1
2) IcePower + PSU - SOLD
- 2 x B&O IcePower ICE1000A
- 2 x upgraded PSU for ICEPOWER1000A (220v-240v)
- 2 x B&O input stage & signal harnesses.
(ebay item 282969957032)
Condition:
1) Holton - I had never installed the modules or connected the to power so basically they are new.
2) IcePower + PSU - I connected them for a testing only.
Prices:
1) Holton - SOLD!
2) IcePower - SOLD!
payment via Paypal only.
Ice-power is sold.
Holtons parts still for sale, really High-end equipment. 20180531_155845.jpeg
Amp Modules Specifications:
150 Watts RMS continuous sine wave into 8 Ω
260 Watts RMS continuous sine wave into 4 Ω
2 Ω Stable
Biased into Class A/B
Frequency Response 3.5hz to 300khz -3dB
Dampening Factor At 100hz 8Ω = 800
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
SNR -105dB
THD-N = 0.005% @ 10 watts 8 Ohms
Recommended Linear Voltage Supply +-63 volts DC
PSU Power Transformer secondary windings 45vac (400VA)
Printed Circuit Board Dimensions 66mm x 50mm
Recommended Conrad Heat Sink MF25-75
Ultra small form factor PCB
Designed as high performance Home Theatre multi-channel amplifier
Or High End 2 Channel stereo amplifier
Unconditionally Stable into any load from 4 ohm loads and up
Extra Heavy Duty Two ounce copper printed circuit board
Rugged high performance complementary Dual Die Lateral MOSFET Output Stage.
