Swap Meet Sell your stuff here, who knows, some other fanatic might be interested!
FS: Holton Modules / ICE-Power
Old 18th June 2018, 11:13 AM   #11
RoyAlpine is offline RoyAlpine  Israel
Send a message via AIM to RoyAlpine Send a message via MSN to RoyAlpine Send a message via Yahoo to RoyAlpine
one Holton set is Sold and shipped to Japan! I have one more. (and Last!)
Old 21st June 2018, 08:48 AM   #12
bump...
Old 25th June 2018, 12:40 PM   #13
Exicon lateral Mosfets!
Old 25th June 2018, 12:55 PM   #14
coolnose is offline coolnose  Europe
coolnose's Avatar
Now that's a punchline!
Old 2nd July 2018, 11:19 AM   #15
Amp Modules Specifications:
150 Watts RMS continuous sine wave into 8 Ω
260 Watts RMS continuous sine wave into 4 Ω
2 Ω Stable
Biased into Class A/B
Frequency Response 3.5hz to 300khz -3dB
Dampening Factor At 100hz 8Ω = 800
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
SNR -105dB
THD-N = 0.005% @ 10 watts 8 Ohms
Recommended Linear Voltage Supply +-63 volts DC
PSU Power Transformer secondary windings 45vac (400VA)
Printed Circuit Board Dimensions 66mm x 50mm
Recommended Conrad Heat Sink MF25-75
Ultra small form factor PCB
Designed as high performance Home Theatre multi-channel amplifier
Or High End 2 Channel stereo amplifier
Unconditionally Stable into any load from 4 ohm loads and up
Extra Heavy Duty Two ounce copper printed circuit board
Rugged high performance complementary Dual Die Lateral MOSFET Output Stage.
Old 9th July 2018, 07:46 AM   #16
Still here
Old 14th July 2018, 01:15 PM   #17
400$ shipped ! ! ! its a steal.
FS: Holton Modules / ICE-PowerHide this!Advertise here!
Holton Precision Audio HPA-NXV500 MOSFET Amplifier Modules jackson7575 Swap Meet 5 1st April 2017 09:09 AM
Any Experience With Holton Precision Amp Modules? Taipan Solid State 0 16th June 2016 08:57 PM
2x Holton Precision Audio HPA-NXV500L Lateral MOSFET Amplifier Modules ShinOBIWAN Swap Meet 6 3rd June 2016 05:31 AM
Holton Precison Audio HPA-nxV500 Modules ShinOBIWAN Swap Meet 15 31st October 2015 09:53 AM
Holton Precision Audio dual mono amp kit using hpa-nxv201ps modules Electro3000 Swap Meet 0 14th September 2010 07:51 PM
