Hello.
Since I have a lot of speakers and just a few time, small place and I have to move in a couple of months, here for sale a pair of Jeff Bagby KAIROS bookshelf with SEAS SP18R passive radiator.
Crossover is built with high quality components: Audyn Cap Plus 2% tolerance, resistors and coils Jantzen Audio and Silver wires and solders.
You know that only drivers and crossover components are above 900€. They were bought in feb 2018 and had been played for less than 10 hours between listening and measuring, so they are like new pristine condition.
The cabinets has been built from CNC pieces in a personal design. They have bitumen pads inside as well as acoustic absorber. Weight for each is about 15 kg. They have 16 liters net volume and dimensions are 42x20x35cm (HxWxD)
Unfortunately veneering job was not good and you will see some defects in the sheets joints, but they can't be seen at listening position because they are located mainly in the bottom and back of the cabinets.
Sound is incredible good: smooth highs and and deep and dry bass helped by the passive radiator.
Here you have some measurements including each driver at crossover point and general system.
Taking in consideration the veneering problems prices as follows:
Full bookshelf speakers: 800€ shipped to EU + PP fees
Drivers set (with original boxes):
2 x Satori MW16P-8 Middrivers
2 x Satori TW29R Tweeters
2 x SEAS SP18R Passive radiators
2 x Fully built crossover (Adyn Cap plus, and Jantzen Audio components)
650€ shipped to EU + PP fees.
Some pictures:
Some pictures:
