DIY First Watt F4 + BA3FE preamp
DIY First Watt F4
For sale is my F4 power amp.
I built the PSU with higher rail voltage than standard to increase the output power. Here are the details:
F4:
- hifi2000 deluxe 5U case 450x400x210 mm.
- heavy duty 40mm rubber feet for good ventilation
- 600VA audio grade toroidy transformer 230 primary 2x24VAC secondaries
- CRC PSU with 8x27000u/50 panasonic 105º panasonic TSHA capacitors
- VDC is 30V when biased
- JFets removed from the circuit (aka Crippled F4, not necessary with the BA3FE preamp), I can install these if requested at no extra cost.
- 16W (0,55A) bias per mosfet giving roughly 40W class A @ 8ohm and around 100W in class AB
Price: 600€, shipping should be around 100€ for most countries in europe.
Any questions don't hesitate in sending me a message.
Manuel
QS3PdZ5nx_DF6PVPfV5WuKLFzqCIEQszRVx3MdOZNWzuzTAloNXxZy791GWdDBC8L48JaxYXvEFGmBPrAl2tOzBhZWxtgDQ3SGkJkMZoQZCZfbTVXdRRACkxqOYLS8TM_LnBuKWAaDpbi4tw_K9Y_dombzeeip6NIaJQ7jbi0A-nMu6unR9hVOmW73OMljG0asN2iAkYvQlXBAAQMe8yEkyUTd-IjB82XYgAuExZmzju0NdRkx5o0w0lhPUQZeJ0YtCYeybL-V0bV4d_SUTex6Uo02CytB6D-h2FsXGphq1u53DvUYBM8hYt8vmVy1sWhjmqrWyySokVGZId7dkHpkwjLorM7Spt754rmanbM4qKazszm8o9WDe2gIiBI80YR-r2B_eBwYuryN6dwi8Vn2QIAffYOmY983mhcpryniwir1s2aN4HRZyne4EoscCVyosaIaC3AIj4AIDz7qU1Wlr4_GhDrpkkAYR8qQFwvC7VS-ic3KffEjFy3TgmAk_YG7ul6EjgTUdLin5uYUXWsOYgLEEgnl8ciIGBHGGAKkKHPGU5B_DQLvdULmY-B6fDN7EhT-o_vSV8ZK_VT69NxWGPgMZXPpbWqTBBb26ZYIp64oZTPy7U-OQ642Uyg0AkywMBMPmTdV9uIm1bqNHAvgr05eHqRSWw=w912-h513-no
HyGKnFQ-kkYIewiKUedfXdXECONAOBvJDxes__aBbLqm-yOdCagdLJdvjjWgQjS8AzDsrxUlYotCYmkbjS9fTriTebw1m3SiKQd6QhNq9slh1AUxEn8jiFEDqVMbb9VaAK2B3p7NDWW8INTgSNIn_vorPWFaXmLA2h96HlYtg15xhLPZsTfIdL3t79tUgeWLnoyaLWbIbMDulnrdSkVo2AoflwQXRj1wSyUlcFslR8wrB98wxGqg7E9hhV7I09DXdeG825kDWAQ0SgzBqmyl_gLfYxDTrfDNzZdOvM70bkBOHBenQppR3HtW06NV3urQ1JrDss-KafD9CXDXDXBmHhLQPijuNXyEp_7jCiCWg4xYXLEVdVKeITjbxxkvvZTBLcpn-6evGcUkX9IhiZNRiLKwP6YGm4kwdWB2S6LGXYaIARBDMULQN3uJuJJe7d_HW7Y7Xx-RmJc7_r7nm7BtnMgpo0VD91G5VbnxY_OqibG1vOpGYxoEC6SBYrFo52KrC3vzBvKcVN1Mhrlw6_yqrg2n2rJtFtID06CHeZKy4RmSgd7O1dtMN6VdtdOG3mSldP94QYCYY8YpsYngkLDxXOhunp8GAXTo4OF7ifnWHq-OxC7Tpx_5r-zrle5YLqwlfB1zkDo9gW0lecFf5Vx4rlqqlpZwakfE=w1024-h576-no
