Custom Seas Aluminum Cone Woofers
Optimized for low frequency use in a 2 way bookshelf or four drivers (series/parallel connection) in a floor standing/tower speakers.
Suggested Enclosures
Sealed
Suggested cabinet volumes are between 7 and 15L. The latter yields a Butterworth alignment with a bass system resonance of 50Hz and a frequency response that is -3dB at 50Hz.
Ported
Suggested cabinet volumes are between 10 and 25L. The latter yields a Butterworth alignment when tuned to 29Hz with a 2" ID x 10" port. The frequency response of this alignment is -3dB at 30Hz.
Measurements and Example Crossover
This custom Seas woofer was installed in a sealed enclosure and a passive crossover was designed for an acoustic 2nd order LR low pass transfer function with a crossover frequency of 2KHz. This is a great transducer for a 2 or 3 way bookshelf or tower speaker crossed over to a midrange from 100 to 750Hz or a tweeter at 2 to 3KHz.
Frequency response graph with and without passive crossover (schematic below). Calibrated mic at 1M, 2.83V.
Schematic Diagram of a 2nd order LR low pass transfer function with a crossover frequency of 2KHz.
