Lambda Acoustics and AE/Stryke Audio drivers for sale
NOTE: All items now sold. Thanks for looking.
G'day All
I'm in the process of downsizing and need to move on a pile of speakers. I'll consider reasonable offers, especially for multiple items. Paypal and shipping available.
Located in Canberra, Australia.
Lambda Acoustics 12001-PFPHN-4AF drivers in excellent condition. $300Pr
AE Speakers / Stryke Audio / Lambda Acoustics Frankenwoofer with two 15" passives and box.
This is a sort of hybrid woofer between the AV woofers and the Lambda woofers. It uses the cone and surround from the Stryke Audio (Now AE Speakers) AV series subwoofers with the Lambda motor designed by Nick McKinney. It has 22mm Xmax and a full copper sleeve for low inductance, distortion and thermal compression. This awesome driver comes in a braced plywood box with two 15" passives for an F3 of below 18Hz. Very little use, works as new. Seriously low and loud for such a small subwoofer.
Parameters are as follows:
Fs: 27hz
Qms: 9
Vas: 36L
Cms: .12mm/N
Mms: 290g
Rms: 5.46kg/s
Xmax 22mm
Sd: 460sqcm
Qes: .47
Re: 2.75ohm (coils in series)
Le: .56mH
Z: 4ohm nominal
Bl: 16.9Tm
Pe: 700W
Qts: .45
In 3cf with the pair of 1400gram 15" PR's gives an Fb right around 20hz and F3 of 17.85Hz. Pickup only. $300
Feel free to drop me a message if you have any questions.
G'day All
Fs: 27hz
Qms: 9
Vas: 36L
Cms: .12mm/N
Mms: 290g
Rms: 5.46kg/s
Xmax 22mm
Sd: 460sqcm
Qes: .47
Le: .56mH
Z: 4ohm nominal
Bl: 16.9Tm
Pe: 700W
Qts: .45
